The distance from the top of a block floating in the water to water
The discussion revolves around calculating the distance from the top of a wood block to the water surface when the block floats. The block's dimensions are 8 cm x 8 cm x 8 cm, and its density is 653.49 kg/m3. Initial calculations led to confusion due to inconsistent unit usage, particularly mixing centimeters and meters. After correcting the units and recalculating, the height of the un-immersed part was mistakenly reported as 7.9477 m instead of the correct conversion. The participant plans to consult their professor for clarification on the discrepancies in their calculations.
PoPrOcKsRoCk
A 8 cm × 8 cm × 8 cm wood block with a density of 653.49 kg/m3 floats in water.
What is the distance from the top of the block to the water if the water is fresh?
weight= density*volume*g
weight=653.49*(512)*9.8
weight=3278951.424 Newton
weight=densitywater*g* 8 cm* 8 cm*depth
3278951.424=1000*9.81*8*8*d
3278951.424=627200*d
d=5.22792 cm...which is wrong
I have also tried subtracting 8 from 5.22792 and I got 2.77208 cm. I tried to submit it into my homework website and it is telling me I am wrong. I just don't understand what I am doing wrong.
Yeah well, your units of length are not consistent throughout the calculation. In some quantities, you use centimetres and in other quantities you use metres.
Also, the "d" you are calculating is the height of the immersed part. You want the height of the un-immersed part.
So I would need to change the 8 cm to 0.08 m, right?
If I do that, then my answer would be;
weight=653.49*(5.14*10^-4)*9.8
weight= 3.2788 Newton
3.2788=1000*9.8*0.08*0.08*d
3.2788=62.72*d
d=0.0522768 m?
And the height of the un-immersed part is 7.9477 m?
The last part is def. wrong. Remember, the height of the box is 8 cm, not 8 m. So you need to subtract your final answer from 0.08, not from 8. Assuming you did the calculations right (which I haven't checked), this means that more than half the box is immersed.
I tried the answer 7.9477 m and it told me I was right. I don't understand how though because the 8 is in cm and the 0.0522768 is in m. I will have to talk to my professor about that. Thank you for your help.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
