Pleiades7
- 1
- 0
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion?
In a second scenario, imagine a person with a body mass of 70 kg standing on a scale while holding two 5 kg weights, one in each hand. The total reading on the scale is therefore 80 kg. If the person then begins to rotate rapidly around their own vertical axis, the arms will extend outward as the weights experience an increasing centrifugal effect. In this state, the acceleration of the weights becomes largely horizontal rather than vertical. Would this redistribution of forces alter the total normal force on the scale, and consequently, the measured weight?
This setup can also be modeled mechanically: two equal masses are attached to opposite ends of a rotating rotor, which is placed on a scale and spun at high angular velocity.
The central question, therefore, is whether any object rotating rapidly about its own axis in a plane parallel to the ground exhibits a measurable reduction in its apparent weight due to the redistribution of centripetal and normal forces.
