How Do We Calculate Mercury's Gravitational Field Intensity?
To calculate Mercury's gravitational field intensity, the relevant formula is F = Gm1m2 / d^2, where G is the universal gravitational constant. The mass of Mercury (3.28 x 10^23 kg) and its radius (2.57 x 10^6 m) are provided, but the mass of Earth is not necessary for this calculation. The discussion emphasizes understanding the difference between gravitational field intensity (N/kg) and gravitational force, highlighting the importance of unit consistency. Clarification on the definitions of little g (acceleration due to gravity) and big G (universal gravitational constant) is also sought. Ultimately, the focus is on correctly applying the gravitational field intensity formula to derive the answer.
NeomiXD
On Earth, the gravitational field intensity is 9.8 N/kg. Mercury has a mass of 3.28 x 1023 kg and a radius of 2.57 x 106 m. Calculate the gravitational field intensity on Mercury in N/kg.
Given:
g = 9.8 N/kg (on earth)
m = 3.28 x 10^23 Kg
d = 2.57 x 10^6m
Required:
g = ?
Solution:
I was just wondering what given would be used and what equation would you use to solve this question; F = Gm1m2 / d^2 or F = mg.
What is the definition of little g? What is the definition of big G? (I don't mean the value. I mean the definition from a conceptual sense.)
One of those two is universally applicable. The other is not. That should give you a clue as to which equation to use.
G in the universal gravitational constant (6.67 x 10^-11 Nm^2/kg^2). So, I have to F = Gm1m2 / d^2 to solve this question...but isn't m2 (mass of Earth) not given?
Why do you care about the mass of the Earth? Where are you performing this calculation?
Consider the units involved. The problem asks for the gravitational field intensity, which has units of N/kg. Is this the same thing as gravitational force? What are the units of gravitational force? What do you need to do to make the units match?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
