The Gyro Effect explains why increased spin motion leads to greater resistance when attempting to alter a spinning wheel's axis. Contrary to popular belief, a gyroscope does not resist rotation; instead, it reacts by moving at nearly right angles to applied forces. When attempting to tilt a spinning wheel, the necessary centripetal forces create torque that acts around a vertical axis rather than the expected horizontal one. This results in a paradoxical response where the gyroscope appears to resist changes in its orientation. Understanding this behavior clarifies the dynamics of gyroscopic motion and its implications in various applications.
#1
johann1301
216
Why does a force used to twist/alter the spin-axis of a spinning wheel increase when the spin motion increases? Why this Gyro effect?
It's a common misconception that a gyroscope resists having its axis rotated. More accurately, it responds paradoxically to such forces by moving at almost right angles to them.
Imagine trying to push a shopping trolley with its wheels jammed way to the left. If you try to push it forwards it goes left. If you try to resist its going left, you will feel it resists moving forwards, but that's your own resistance played back to you.
It's much the same with a gyroscope. If you mount it in a gimbal so that it is free to turn either way, then rotate one part of the gimbal manually, the gyroscope responds by rotating in the other swivel direction. You won't feel much resistance now.
As to why... imagine a wheel rotating, top away from you. Suppose you wish to tilt the wheel to the right. The part nearest you needs to switch from moving vertically upwards to moving up and to your right. That's a change of velocity, requiring a centripetal force to your right. Meanwhile the part furthest from you needs to switch from straight down to down-and-to-your-left. That requires a force to your left. So the torque needed is to the right near you and to the left far from you, which is around a vertical axis, not around the horizontal axis as you expected.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
i want to just test a linear generator with galvanometer , the magnet is N28 and the wire (Cu) is of 0.6mm thikness and 10m long , but galvanometer dont show anthing ,
The core is PLA material (3d printed)
The magnet size if 28mm * 10mm * 5mm
If the universe is fundamentally probabilistic, and all possible outcomes are realized in some branch of the multiverse, does that invalidate the concept of scientific inquiry? If knowledge is merely a description of one particular branch of reality, does it have any inherent value?
