The Klein-Gordon equation with a potential
Sekonda
Hello,
My question concerns the Klein-Gordon Equation under some potential of the form (and refers to a higgs-like interaction, i assume as that's what we're researching):
\delta V= \lambda \Psi^{*}\Psi
For substitution into the Klein-Gordon equation:
(\frac{\partial^2 }{\partial t^2}-\bigtriangledown ^2+m^2)\Psi=\lambda \Psi^{*}\Psi
This is all in reference to the feynman diagram of:
The internal line is supposed to represent some scalar mediator, and we also assume the \Psi are 'free' states. Also there are \lambda factors at the vertices of the feynman diagram, I believe this to be just some scaling factor of the perturbation - however I'm not sure. Also from what I've wrote the Psi's in the potential may have subscripts i' and f' but I'm not really sure why this is (they may supposed to be i and f?)
I don't understand much of this - beginning with my main issue of the form of the perturbation being what seems to be a probability density? Also I'm not really sure what interaction is exactly happening in this feyman diagram.
If what I have wrote is nonsensical, please tell me why so and I'll see if I can clear anything up. Any explanations will be appreciated!
Thanks guys,
SK.
My professor has told me that the use of the Psi's in the potential is 'not really a 'potential' but a non-linear term we add to the wave equation that induces self interactions of the wave'
Does anybody know why self-interactions are caused by terms like ψ*ψ?
Thanks
How \delta V= \lambda \Psi^{*}\Psi is an interaction term and what is that λ.I can not see any kind of interaction associated with this term.
lambda is a coupling constant. perturbative expansions are taken around lambda small. As to why certain terms intuitively lead to vertices, and the powers of fields directly correspond to the number of legs entering the vertices, I would love to know. You can find many derivations starting from a scalar action that work out the perturbative expansions in \lambda and J for some source. But as far as why nonlinearity equates to interaction I'm still not sure. If you look through some of the past threads here I can guaranteed the question has been answered though, it just might be buried somewhere deep.
Thanks guys for the information, I'll have a look around.
Lambda is the coupling constant - is this basically the coupling of the particle to the field? What does it mean?
Thanks
Look at Leonard Susskind QFT courses in YouTube. That is explained in the first or the second course (each one have 10 lectures) in a very intuitive manner.
More or less, the idea is that ψ, \phi or A are creation / destruction operators so if you write, for example, ψ(x)*ψ(x)*\phi(x) you are saying that you are creating 2 ψ particles and 1 \phi in position x from nothing (or destructing 1 and creating 2, or creating 1 and destructing 2 and so on).
So, in that way one can interpretate that, for example in the 2 desctruction-1 creation example, a ψ particle interacts with a \phi particle, it sort of eats it and as a result we have a ψ particle. All this being said in a veeeeryyyy intuitive way.
Hope it helps
Thank you for the suggestion of the youtube videos, I can tell this will help me understand this whole subject a lot better. Though there are quite a few so I better get watching and making notes!
Thanks again the_pulp!
I still don't get it,if λ is a coupling constant then where is the coupling term.I mean let's take qed for example in which coupling term is of form jμAμ,where jμ is current associated with particles and Aμ which represents potentials.only this term corresponds to interaction in qed.but I can not see anything similar with the given interaction because to me it does not seem any interaction.
It's coupling to itself. here are some example couplings: (\lambda / 4!) \phi^4 is common example. Also (\lambda /4!)(\phi \phi^{\dagger})^2 is another example where there are anti-particles, the phi and phi dagger.
yes,it is a kind of self interaction.I was just not thinking that both ψ* and ψ should be associated to same spacetime point to cause interaction.It was generating the anharmonic term which gives interaction
jfy4 what do you mean when you say we take perbutative expansions around λ?
Thanks!
I mean, starting with the partition function, one can expand the exponential of the potential term in a series expansion in \lambda (the coupling constant, there's nothing special about the letter lambda). Then, in nice cases you can write the poential as variations in a source J, V(\delta / \delta J). One can solve the free field partition function in terms of the propagator and sources, and then pull down green's functions with the variations in J. These will be related to whatever order you decide to take the series expansion to in \lambda.
But there is no source term J here which has really caused me trouble something like J∅,in qed jμ is generally ieψ*γ0γμψ but here there is no such thing.
for the complex klein gordon equation you can write one as J^{\dagger}\phi + J\phi^{\dagger} and for the real one you can write J\phi. You can set J equal to zero when you are done with the perterbative expansion.
There is no necessity of it,one can directly go on with iL(lagrangian) and put the planewave form and separate all the unnecessary terms(factors taken care by external line etc.) to get the vertex factor.one can put the interaction term equal to delta function and go to momentum space to find the propagator.But so far there is no internal line corresponding to ay virtual quanta as is drawn because there is no source term and it's interaction with any field.
The r.h.s. of KGE should read:
<br /> \frac{\lambda}{2} \left(\Psi^{\ast} \, \Psi \right) \Psi<br />
for a self-interaction of the type the Higgs boson has:
<br /> \mathcal{L}_{\mathrm{int}} = -\frac{\lambda}{2! 2!} \, \left( \Psi^{\ast} \, \Psi \right)^2<br />
Second one makes sense,first one does not.
The KGE is the Euler-Lagrange eqn. for the action defined as S = \int{d^d x \, \mathcal{L}}, where the Lagrangian (density) is:
<br /> \mathcal{L} = \mathcal{L_0} + \mathcal{L}_{\mathrm{int}}<br />
Here \mathcal{L_0} = \partial^{\mu} \Psi^{\ast} \, \partial_{\mu} \Psi - m^2 \Psi^{\ast} \, \Psi is the Lagrangian for the free complex scalar field. Varying w.r.t. \Psi^{\ast}, one obtains:
<br /> \frac{\delta S}{\delta \Psi^{\ast}(x)} = -\left\lbrace \partial^2 + m^2 \right\rbrace \Psi(x) - \frac{\lambda}{2! 2!} 2 (\Psi^{\ast} \Psi) \, \Psi<br />
Equate this variation to zero and you get:
<br /> \left\lbrace \partial^2 + m^2 \right\rbrace \Psi = - \frac{\lambda}{2} (\Psi^{\ast} \Psi) \, \Psi<br />
Apart from a wrong sign, the r.h.s. has the form I gave in my previous post.
I thought your first term also some sort of a lagrangian which is not possible.
How can a Lagrangian term be present in a Klein-Gordon equation?!
Yes you are right with the correct potential form, though I assumed it was in relation to the Higgs boson as this is what the topic is on though I'm guessing a potential of this form is just an example to familiarise ourselves.
I did not read it rather just see.
Hey I think the form of the potential was supposed to be this:
\lambda\Psi_{f&#039;}^{*} \Psi_{i&#039;}
such that:
(\frac{\partial^2 }{\partial t^2}-\bigtriangledown^2+m^2)\Psi=\lambda\Psi_{f&#039;}^{*} \Psi_{i&#039;}
Is this right?
For a complex scalar field theory you want a partition function of the form
<br /> Z = \int D\phi \exp \left[ i \int d^4 x \frac{1}{2} \{ \partial \phi \partial \phi^{\dagger} + m^2 \phi \phi^{\dagger} \} + V(\lambda , \phi, \phi^{\dagger}) + J^{\dagger}\phi + J\phi^{\dagger} \right]<br />
you can then assume weak coupling and expand the potential order by order in lambda, and replace the moment integrals with variations with respect to J, \delta / \delta J, like
<br /> \int dx \, x^2 e^{-\alpha x} = \frac{\partial^2}{\partial \alpha^2} \int dx \, e^{-\alpha x}<br />
doing this, along with a regularization procedure, you can make all the connected green's functions and feynman diagrams.
Hmm I don't understand most of that - though it does sound like the route we are taking. Does the equation I just posted make sense at all though? Are you implying that it is and it's a complex scalar field?
I haven't actually had any substantial teaching of quantum field theory, we're supposed to be taking a simplified route so forgive me for not understanding most of the terms you speak of (i.e. the partition function - I've heard of that but not applied to this!)
Thanks!
something doesn't seem right... If I understand you correctly you are writing
<br /> V(\Psi, \Psi^{\dagger}) = \lambda \Psi \Psi^{\dagger}<br />
then the lagrangian would be
<br /> \mathcal{L} = \frac{1}{2}\partial \Psi^{\dagger} \partial \Psi + \frac{1}{2}m^2 \Psi^{\dagger}\Psi - \lambda \Psi^{\dagger} \Psi<br />
If you solve Lagrange's equations for \Psi or \Psi^{\dagger} you will not get what you have posted. If you want to get a vertex with three lines the potential needs to be cubic in field quantities. but with a complex field it will be asymmetrical too since you will write down a term like \Psi\Psi^{\dagger}\Psi which is uneven in the two fields. For real fields it would be like \phi^{3}/3!.
Well it probably isn't right knowing me, my professor said we model the perturbation as the interaction between some 2 scalar particles which is of the form of some coupling strength lambda and the product of the complex conjugated final state wavefunction of particle 2 and the initial state wavefunction of particle 2...
I shall send him an email tomorrow and ask!
I apologise if I'm not coherent/making sense.
Thanks,
Tom
please report back! :) I want to know too.
haha will do!
I think that interaction term posted by dickfore is the right one,it seems that in post #27 that is what is being said.
  • #31
Hey,
My professor says an equation of this form:
(\frac{\partial^2 }{\partial t^2}-\bigtriangledown^2+m^2)\Psi=\lambda\Psi_{f&#039;}^{*} \Psi_{i&#039;}\Psi
Will give a 4 particle interaction where I need to make the 'f'' state on the rhs an external (not sure what this means yet) and this useful for looking at the Higgs.
Whereas an equation of form:
Is a 3 particle interaction where they meet at a junction and some internal scalar particle is propagated.
  • #32
sure, I don't have a problem with that. But I don't think that is a consequence of a potential of the form V=\lambda \Psi^{\dagger}\Psi. I think the potential must have a different form if the r.h.s of the equation looks like that.
  • #33
Well he included a delta sign next to the potential i.e. it was δV=λψ*ψ, are you supposing it should be δV=λψ*?
