Mentor
- 23,899
- 11,355
I think it will be expensive.Dale said:Interesting. Why do you think that?
I don’t know for sure the arguments on the other side, but I think that the idea is that your fixed costs will indeed be high but your variable costs will be low.russ_watters said:I think it will be expensive.
I'm not answering for Russ, but with respect to "To me it seems more likely at this point that even if fusion can be made to work it will still be a bust," 1) one would have to define what "to work" means, and 2) even if it made to work, there is the matter of the supply chain infrastructure.Dale said:Interesting. Why do you think that?
Sure. And for fission, hydro, solar and wind too. The question is, how high?Dale said:I don’t know for sure the arguments on the other side, but I think that the idea is that your fixed costs will indeed be high but your variable costs will be low.
What does that translate into in $/MW-hr? And how much energy does it take to create the "fuel grade" D2?Astronuc said:I can't find the price for D2 gas, which is probably more than $100/kg, and T2 is considerably more expensive.
russ_watters said:So can you explain what this "vast reward" is and on what basis you are so confident in it?
Well it hasn't been invented yet, but there are some speculative schematics out there about how it might work:gmax137 said:I don't recall ever seeing a full-plant design concept. I mean aside from the particle physics and magnets. How do you get the heat out? Do you boil water and use a Rankine steam plant to turn the generator?
It wouldn't need those systems per se, but given the exceptionally extreme, difficult to maintain conditions of the reactor, the extra systems required for fusion may be more complex than for fission. It also points to a potential for fusion power to be dangerous and unreliable.gmax137 said:Unlike a fission plant, it seems to me you wouldn't need the containment, or all of the core-flooding and decay heat removing safety systems (and their supporting systems, emergency diesels, safety grade ultimate heat sink, redundant controls, on and on).
That's nice, but the same can be said for solar and wind. And, depending on your framing criteria, fission too.bhobba said:The fuel is virtually limitless here on earth, with little or no pollution.
Yes, and it's really hard to accurately estimate the cost of something that hasn't been invented yet. Aspirational technologies are always championed by optimists. Sometimes they are right, often they are not.bhobba said:But I take your point. Engineers, economists, actuaries etc., would need to do a detailed cost-benefit study comparing it to other energy sources available when and if it eventually happens. So a better way of expressing it would be that many people think it can be a transformative technology.
On second thought, it is good you raised it. I am critical of aspirations like carbon neutral by 2030 without a detailed cost-benefit analysis.
That is my understanding as well. For fission power, fuel costs are a much smaller percentage of total life cycle costs, and initial capital investment is a much larger percentage, as compared with chemical fuels. This would be expected to be even more extreme in the case of fusion since the energy yield per unit mass of fuel is larger for fusion than for fission. So even if the cost per unit mass of fuel is several orders of magnitude higher than for chemical fuels, the impact of fuel costs on total life cycle cost can still be competitive. Also, fuel costs would be expected to decrease if fusion power became widespread and there was a large economic incentive to find more efficient ways of obtaining fusion fuels. (The same can be said for fission fuels, of course.)Dale said:I think that the idea is that your fixed costs will indeed be high but your variable costs will be low.
Once upon a time (late 1970s, early 1980s), there was a STARFIRE commercial fusion reactor concept.gmax137 said:I don't recall ever seeing a full-plant design concept. I mean aside from the particle physics and magnets. How do you get the heat out? Do you boil water and use a Rankine steam plant to turn the generator?
A lot of wishful thinking went into that.The reactor delivers 1200 MWe to the grid in addition to providing 240 MWe for recirculating power requirements. The reactor operates with a continuous plasma burn and develops 4000 MW of useful thermal power.
There is no fission, unless they put a breeding blanket of 238U on the periphery. There have been fusion-fission hybrid concepts. Even without fission, one may have large quantities of tritium both as a fuel and as a product. For d+d -> t + p, roughly about 50% of the time. That has to be contained somehow. They could also breed T in blankets of Li, which requires a secured facility.gmax137 said:Unlike a fission plant, it seems to me you wouldn't need the containment, or all of the core-flooding and decay heat removing safety systems (and their supporting systems, emergency diesels, safety grade ultimate heat sink, redundant controls, on and on). Not only avoiding those construction costs, but also the monthly surveillance testing on all that stuff throughout the plant life.
With no fissionable materials on site, you don't need a huge security staff.
It is a concern but on a larger scale for a power reactor system.A 9.4 Tesla superconducting magnet, used for mass spectroscopy in a campus laboratory recently suffered a catastrophic failure. The incident was apparently caused by over-pressurization and failure of the liquid helium (LHe) chamber. Although there were no injuries because the incident occurred during off-hours, the potential for significant injury due to the venting of LHe into the facility was present. There was also significant damage to equipment associated with the magnet.
A magnet achieves superconductivity (zero resistance to electrical current) when it is bathed in LHe. If for some reason the magnetic coil starts to resist the electrical current, it heats up, causing an explosive expansion of the LHe. This expansion of gas is vented through a large bore vent, sealed by a membrane called a "rupture disk". This process of explosive venting is known as a "quench".
I think I was editing my post when you quoted. I had raised my cost estimate for D2 to more than $1000/kg.gmax137 said:What does that translate into in $/MW-hr? And how much energy does it take to create the "fuel grade" D2?
I guess it's like that old saying "if your not a socialist in your 20's you have no heart but if your not a capitalist by the time you are 30 you have no brain..."Astronuc said:As an undergrad and graduate student, I was keen on fusion and fast reactor technologies. Professionally, I ended up working mostly in LWR technology (fuel and core components, and materials) and some special nuclear applications.
The Fusion Technology Facility will house a range of test rigs, including the Combined Heating and Magnetic Research Apparatus (CHIMERA) device, which is being designed and built by Jacobs and Tesla Engineering Limited. The CHIMERA test rig is said to be the only device in the world that has the ability to test prototype components in an environment that simulates the conditions inside a fusion power plant. Within the UKAEA facility, component prototypes will be subjected to a combination of high heat and magnetic field within a vacuum environment, as well as thermal cycling.
https://www.world-nuclear-news.org/Articles/Components-for-Summer-headed-to-UkraineCompletion of unit 4 of the Khmelnitsky nuclear power plant in Ukraine will be accelerated by the use of major plant components in storage since the construction of new reactors at VC Summer in the USA was cancelled. The head of Energoatom toured Westinghouse warehouses to inspect the condition of the AP1000 components.
Outside of the core, PWR components are fairly generic, except for key dimensions, e.g., main/primary piping dimensions. Otherwise, there can be some adaptation. The balance of plant is essentially agnostic with respect to the core geometry. The steam generators do not care from where the heat originates, but one would try to match the heat flux and change in enthalpy in primary and secondary systems - within reasonable tolerances.artis said:Given they have started VVER are they now fitting an AP1000 in that frame?
artis said:What I don't understand is which type of reactor are they trying to finish there?
Kotin signed a Memorandum of Cooperation with Patrick Fragman, Westinghouse president and CEO, last week which foresaw the completion of Khmelnitsky 4 "using AP1000 technology." The reactor started out as a VVER design in 1987 but construction stalled at 28% completion.
She is correct. If I recall correctly, back when I studied fusion, we were looking for a Q ≥ 20 to have plant produce net power. The power conversion (plasma energy to useful electrical energy) part was critical.green slime said:"How close is nuclear fusion power?"
Astronuc said:She is correct. If I recall correctly, back when I studied fusion, we were looking for a Q ≥ 20 to have plant produce net power. The power conversion (plasma energy to useful electrical energy) part was critical.
The three methods for transformer the plasma (thermal) energy to electric current are:Astronuc said:The power conversion (plasma energy to useful electrical energy) part was critical.
Wouldn't there also be the option for a fourth way if some of the designs were to ever gain net energy , like converting produced heat to steam/gas turbine/generator + taking the plasma exhaust in the form of hot gas and introducing that directly to a turbine.Astronuc said:The three methods for transformer the plasma (thermal) energy to electric current are:
1) traditional approach of transforming thermal (heat) energy to mechanical (e.g., steam or gas turbine) to electrical (generator)
2) induction, in which the plasma expands against the magnetic field to induce a current
3) direct energy conversion through charge separation, where the electrons flow through the load to recombine with the positive charges (H or He nuclei).
Each has it's set of technical challenges.
No, the plasma operates in a near vacuum, with very low atomic density (~1014 /cm3). The high pressure, due to the high temperature, is accommodated by the confining magnetic field. Allowing for 'plasma exhaust' mean loss of fuel and heat, which then has to be made up through more heat input and injecting more fuel.artis said:taking the plasma exhaust in the form of hot gas and introducing that directly to a turbine.
PWRs Unterweser, Brokdorf, Grohnde and Phillipsburg 2 and BWRs Gundremmingen B & C are among the most efficient NPPs (LWRs) in the world.Germany's phase-out of nuclear energy will only lead to the country missing its 2030 carbon emissions target, 25 leading foreign and German environmentalists, journalists and academics have written in an open letter to the German public. They call on German politicians to be "brave enough" to change legislation to at least postpone the shutdown of the country's reactors.
I recall an earlier thread where someone said that Germany was also paying money to coal plants to prevent them from shutting down and the coal companies from going out of business. But I can't find the link.Astronuc said:Germans asked to keep reactors in operation
15 October 2021
https://www.world-nuclear-news.org/Articles/Germans-asked-to-keep-reactors-in-operation
Ehh fear, where would we be without you... better off I'd say!Following the accident at the Fukushima Daiichi plant in Japan in March 2011, the government of Chancellor Angela Merkel decided it would phase out its use of nuclear power by the end of 2022 at the latest. Prior to the accident, Germany was obtaining around one-quarter of its electricity from nuclear power.
The effort to shutdown RBMKs and VVER-440s began mid-1990s after the breakup of the Soviet Union and dissolution of Warsaw Pact. It was driven by US and EU policy. In the US, the DOE established the International Nuclear Safety Program (https://insp.pnnl.gov/ ), which was basically finished by around 2003/2004. DOE stopped supporting the website in 2004.artis said:I don't want to go offroad with my rambling here but EU is also to blame, their scare from nuclear began even before Fukushima. Back in the early 2000, they literally pushed Lithuania to abandon their two Ignalina 1500MWe reactors which were operational and had years to go.
That was part of their deal with joining the EU, closing the two RBMK 1500 blocks. The simple reasoning was something like this - they were afraid of anything Russian and Chernobyl related, a very unscientific stance.
Even though the RBMK's after Chernobyl were retrofitted and monitored more closely than a top security federal prison. The Lithuanian reactors were operating without flaws, they were good to go.
When they operated they provided some 98% of all energy for that country, they were the greenest on planet topping France. My country was second after neighboring Lithuania but only thanks to our huge reliance on Hydro.
https://en.wikipedia.org/wiki/Ignalina_Nuclear_Power_PlantPreparations for the construction began in 1974. Field work began four years later. Unit 1 came online in December 1983, and was closed on December 31, 2004. Unit 2 came online in August 1987 and was closed on December 31, 2009 . . .
