The Pseudo Radiation Energy Amplifier
The paper discusses the concept of the Pseudo Radiation Energy Amplifier (PREA) and its implications for understanding the Earth's mean ground temperature, which is estimated at 15 °C. It highlights a discrepancy between the power received from the sun (342 W/m2) and the power emitted by the Earth (599 kW/m2), suggesting that the Earth emits more energy than it receives. This leads to a calculated black body temperature of approximately -18 °C, which is significantly lower than the observed average. The author proposes that the Earth acts as a gray body, functioning as a Pseudo Radiation Energy Amplifier due to its interaction with incident radiation and the vacuum of space. This model prompts a reevaluation of energy balance and climate control parameters, emphasizing the roles of solar and terrestrial radiation reflection coefficients. The findings suggest potential applications for improving energy use through materials with specific reflection properties.
wolram
Dearly Missed
http://cn.arxiv.org/ftp/arxiv/papers/0811/0811.0357.pdf
(PREA) and the mean earth’s ground
temperature
Ahmed Boucenna
Laboratoire DAC, Département de Physique
Faculté des Sciences, Université Ferhat Abbas, 19 000 Sétif,
Algeria
From the radiation balance diagram1 illustrating
the IPCC reports2 one can estimate the power
received by Earth from the sun at Pin = 342 W/m2
and the power consumed, remitted and reflected by
the Earth and its atmosphere at Pout = 599 kW/m2. It
seems that the Earth emits more power than it
receives. The earth’s ground mean temperature is
estimated at 15 °C. A calculation based on the black
body radiation theory gives an earth’s ground mean
temperature of the order of -18 °C which is much
lower than 15 °C. The important gap between these
calculated and estimated temperature mean values
requires an explanation. Here we show that a gray
body separated from vacuum by an interface and
submitted to outside incident radiation can behave
like a Pseudo Radiation Energy Amplifier. The
Earth which is a gray body separated from the
space by an interface, behaves like a Pseudo
Radiation Energy Amplifier. The balance of the
energy exchanged between Earth and outer space is
reconsidered and the 15 °C Earth’s ground
temperature mean value is then derived. Our result
revives the discussion on the parameters that
control the Earth climate. The solar and terrestrial
radiation reflection coefficients by the Earth and its
atmosphere acquire a privileged role. The Pseudo
Radiation Energy Amplifier can be a starting point
to improve the energy use. The materials having the
adequate reflection coefficients will be indicated for
specific applications.-----------------------------,
I am not sure i understand this.
Sounds strange. Or is this person re-discovering the greenhouse effect ?
It appears to me that he creates energy
Hello, I’m currently writing a series of essays on Pangaea, continental drift, and Earth’s geological cycles. While working on my research, I’ve come across some inconsistencies in the existing theories — for example, why the main pressure seems to have been concentrated in the northern polar regions. So I’m curious: is there any data or evidence suggesting that an external cosmic body (an asteroid, comet, or another massive object) could have influenced Earth’s geology in the distant...
On August 10, 2025, there was a massive landslide on the eastern side of Tracy Arm fjord. Although some sources mention 1000 ft tsunami, that height represents the run-up on the sides of the fjord. Technically it was a seiche. Early View of Tracy Arm Landslide Features Tsunami-causing slide was largest in decade, earthquake center finds https://www.gi.alaska.edu/news/tsunami-causing-slide-was-largest-decade-earthquake-center-finds...
