The slopes of these graphs represent what? (Magnetic Fields)
The discussion revolves around interpreting the slopes of graphs related to magnetic fields in a lab experiment. The slope of the current versus magnetic field graph represents the magnetic field per unit current, which is linked to physical constants and the number of loops in the coil. For the distance (1/r) versus magnetic field strength graph, the slope should yield the permeability of a vacuum, but a calculated value of 2E-7 shows an 85% deviation from the expected 4piE-7, indicating a potential issue with the setup or calculations. The conversation emphasizes the importance of using the correct equations based on the experimental setup, particularly noting that the presence of multiple windings in a coil affects the calculations. Clarification on the problem statement and setup is necessary to ensure accurate results.
RockThis52
For a magnetic fields lab I am asked to graph the data and from there, use the slope to find a certain value.
For one of them, I am asked to plot the current (x) vs the magnetic field (y).
The slope is supposed to give me a value, I have the slope, no clue what the value would represent. After some research I found that people are saying it represents the loops?
No clue what that is.
Anyway I also have to plot the distance (1/r) (x) vs the magnetic field strength (y) and the slope is supposed to be the permeability of a vacuum. I get 2E-7. Using 4piE-7, that's a deviation of 85%. I do have a feeling something is not right here.
Units for 1/r, are 1/m and units for magnetic field are T, while units for current are A.
Relevant equations:
B=(µ0I)/2πr
B=(µ0NI)/2R
This is no homework question, in fact I don't need a numerical answer. I just need to know if I'm on the right track.
Thanks.
The slope is "magnetic field per current", and this is proportional to physical constants and the number of windings in your loop.
That cannot work, the units (and physics) do not match. Can you post the full problem statement?
Yup.
5. Plot a graph of magnetic field vs. the reciprocal of the distance from the center of the
conductor. Use Logger Pro or another graphing tool. Page 2 of the experiment file is set
up for this graph.
6. Calculate the permeability of the air from the slope of this graph. How does it compare
with the permeability of the vacuum?
"Calculate" is better. You can rearrange your equations for B to have the form B*r = ...
This is equivalent to B/(1/r)= and the slope of your graph. You have to know I (and probably N), too.
Oh, that makes total sense. I do have I, but N why do I need? Can't I use the first equation I posted?
If your coil has multiple windings, you have to take that into account.
If you have a straight wire, things are different.
Both formulas apply to different situations, I don't know which setup you have.
Well my set up was just a straight wire, so I'm assuming I use the first equation since there are no visible windings? Either way I could rearrange in both equations, correct?
This is possible, but you still have to use the correct one - the first one, in this case.
13K
