The state of two identical bosons
  • Thread starter Thread starter Wuberdall
    Bosons State
Wuberdall
Hi PF.
If I have two identical bosons, one in the single-particle state \phi_{a}(x) and the other in the single-particle state \phi_{b}(x), the two-particle state of the system would then be :
\psi(x_{1},x_{2}) = \frac{1}{\sqrt{2}}\big(\phi_{a}(x_{1})\phi_{b}(x_{2}) + \phi_{b}(x_{1})\phi_{a}(x_{2})\big)
right ?
Then if both bosons are in the same single-particle state, say \phi_{a}(x), then the two-particle state according the equation above, would be :
\psi(x_{1},x_{2}) = \sqrt{2}\phi_{a}(x_{1})\phi_{a}(x_{2})
But this two-particle state isn't normalized, due to factor of \sqrt{2}.
I can't see were I go wrong, someone who can help ?
That's not an issue. You can always renormalize the wave function. All the wave functions must have unitary norm
Thanks Einj, that helped a lot.
I just found it strange that my textbook would write the normalization factor as \frac{1}{\sqrt{N!}}, for N identical bosons.. But this only seems to be the case where the bosons isn't occupying the same single-particle state.
It would be more accurate/general to write the two-particle state as :\psi(x_{1},x_{2}) = A\big(\phi_{a}(x_{1})\phi_{b}(x_{2}) + \phi_{b}(x_{1})\phi_{a}(x_{2})\big).
And again thanks :-)
Yes indeed. If I remember correctly the right normalization for a bosonic wave function is:
\Psi(x_1,...,x_N;\alpha_1,...,\alpha_N)=\frac{1}{\sqrt{N!\prod_{k=1}^N n_k!}}\sum_{\sigma}\sigma\left(\phi_{\alpha_1}(x_1)\phi_{\alpha_2}(x_2)\cdots \phi_{\alpha_N}(x_N)\right),
where \sigma are all the possible permutations and n_k is the number of bosons in the same state \alpha_k.
I hope I'm not missing anything, but that was the main idea.
Yes, exactly... This gives the correct normalized wavefunction I was looking for. The lecture notees I'm reading has just dropped the factor of \frac{1}{\sqrt{\Pi_{k=1}^{N}n_{k}!}}.
Enjoy the rest of your day :-)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
