Why is the theory of relativity a theory?
In summary, Einstein introduced the theory of relativity in a paper entitled "On the electrodynamics of moving bodies", which addressed the long-standing problem of reconciling classical electrodynamics with our intuitive notions of space and time. The constant speed of light, c, was already hinted at by Maxwell's equations and confirmed by Hertz's experiments with radio waves. Einstein treated c as a postulate in special relativity, leading to a logical and elegant theory that agrees with observation and makes correct predictions. The constancy of c is a fundamental aspect of the theory, and its explanation remains a mystery.
VertexOperator
79
Haven't we proven one of its consequences (time dilation) already using atomic synchronized clocks?
Just as in Geometry we have axioms and theorems. In physics, we have axioms which can be tested and theories based on them which can also be tested. The axiom for Relativity is the constancy of the speed of light for all observers in inertial frames of reference. For GR we have the equivalence principle.
Aha, I should learn my definitions then :)
No - what you have proved is that clocks go out of sync when you accelerate them
to high velocities. The experiment proves nothing more than that.
Actually, it does. The quantitative aspect of the change (i.e. how fast did you accelerate and by how much did the clock go out of sync) is what makes it physics, rather than just handwaving philosophy.
In any case, this is irrelevant to this thread. The OP has discovered the confusion in the term "theory" being used in science, as opposed its pedestrian usage.
Zz.
Coud you guys please help me with this:
So the syllabus dot-point is: Identify that if c is constant then space and time become relative
The answer to it is:
In Newtonian physics, space and time are constants and motion is defined by them. For example, consider a spacecraft moving at half the speed of light (0.5c) towards another planet. An astronaut in the spacecraft now flashes a light beam in the direction of motion of the spacecraft .
What is the speed of the light beam as viewed by someone on the planet? Prior to Einstein, we would have said 1.5c. However, according to Einstein’s Theory of Relativity, the answer is now known to be c...
But WHY is c constant?
Is there a proper scientific explanation to why the speed of light is always c?
Is there a proper scientist explanation to why the speed of light is always c?
No. It is just an observation, and our physical theories are based on it.
It would be possible to live in a universe with Newtonian physics as well*. But this is not our universe.
* particle physics would have to look completely different without special relativity, but let's ignore that here.
Ok, makes so much sense lol :)
How did Einstein make this observation? Please don't tell me it was a thought experiment :O
Does the constancy of c seem stranger to you than Newton's laws of motion? What makes a scientific explanation "proper"?
Science never really answers "why" questions; no matter what answer I give you it, it will lead to another deeper "why". (Hence the old joke about "turtles all the way").
So it might be easiest to treat the constant speed of light as a postulate; that's how Einstein presented special relativity. It is, however, a good postulate, in that it leads to a logical and elegant theory that agrees with observation and makes correct predictions. You might also find the recent thread on this subject interesting.
Edit: this thread https://www.physicsforums.com/showthread.php?t=670253
Nature had already given us a pretty strong hint, as Maxwell's equations of electrodynamics suggest that light should travel in a vacuum at speed c. Indeed, much of the second half of the 19th century was spent trying to reconcile classical electrodynamics with our intuitive (but not empirically confirmed) notions of how space and time should work.
It's worth noting that Einstein introduced relativity in a paper entitled "On the electrodynamics of moving bodies"... That really was the problem of the century.
People did a lot of struggling with the speed of light before Einstein decided to try working out the consequences of that wild idea that c was the same for all unaccelerated observers. He didn't just pull it out of his... hat.
http://en.wikipedia.org/wiki/History_of_special_relativity
"When you have eliminated the impossible, whatever remains, however improbable, must be the truth?" - Sherlock Holmes (Doyle)
Didn't a guy called Hertz use Maxwell's equation and radio waves to find a value for the speed of light?
Thank you for the help guy, I will treat c as a postulate by Einstein.
Also, why is it that the closer to a gravitational field an object is moving the more time dilates? Does gravity affect light in anyway?
It is a consequence of a similar postulate in general relativity: Physics is the same for all free-falling observers.
It affects spacetime, and light is moving in this spacetime. Light gets deflected by gravity, indeed. The strongest influence of gravity on light can be seen (or, well, not seen ;)) in black holes.
yes, and that's the hint from mother nature that I was referring to in #12 above.
Read that thread that I linked - the history and change of perspective over the last century is interesting.
Maxwell himself used his equations to predict the existence of electromagnetic waves. He used results of previous experiments on electricity and magnetism to predict the speed of those waves. It turned out to equal (within experimental uncertainty) the speed of light, which other people had recently measured fairly precisely.
I really wish we study Maxwell's equations in high school :( but we don't do contour integration in high school maths...
I don't see why you can't learn the necessary EM on your own although contour integration is a topic from complex analysis and not, I'm assuming, what you meant to say.
But Maxwell's equations have a lot of contour integrals.
I will try to learn it on my own :)
Check out the book Div, Grad, Curl and All That by Schey
It teaches vector analysis using EM as the basis of learning it so you get a two for one savings and only requires understanding of vector algebra, integral calculus and prereqs to these.
https://www.amazon.com/dp/0393925161/?tag=pfamazon01-20
Those are regular path integrals. I'm not sure where the mixing of the terminology path integral and contour integral came from but the latter applies to complex valued functions along curves in the complex plane. Anyways, good luck in your interests!
Related to Why is the theory of relativity a theory?
1. Why is the theory of relativity called a theory?
The theory of relativity is called a theory because it is a well-supported and tested explanation for how the laws of physics work in the universe. It is based on extensive evidence and has been repeatedly confirmed through experimentation and observation.
2. Is the theory of relativity just a hypothesis?
No, the theory of relativity is not just a hypothesis. A hypothesis is an educated guess or prediction about a phenomenon, while a theory is a well-established explanation for a set of observations. The theory of relativity has been extensively tested and supported by evidence, making it a well-established and accepted explanation in the scientific community.
3. How does the theory of relativity differ from Newton's laws of motion?
The theory of relativity is a more comprehensive and accurate explanation for the laws of motion compared to Newton's laws. Newton's laws are valid for objects moving at relatively low speeds, while the theory of relativity encompasses both low and high-speed motion, including the motion of objects at the speed of light. The theory of relativity also takes into account the effects of gravity and spacetime curvature, which Newton's laws do not.
4. Why is the theory of relativity important?
The theory of relativity is important because it revolutionized our understanding of space and time. It provided a new framework for understanding the laws of physics and has led to many technological advancements, such as GPS systems and nuclear energy. Additionally, the theory of relativity has been confirmed through numerous experiments and observations, further solidifying its importance in the scientific community.
5. Is the theory of relativity applicable to everyday life?
Yes, the theory of relativity is applicable to everyday life. Many of our modern technologies, such as GPS systems and satellite communications, rely on the principles of the theory of relativity. Additionally, the theory of relativity has also helped to shape our understanding of the universe and our place in it. While we may not directly observe the effects of relativity in our daily lives, its impact on our understanding of the world around us is significant.
