The thinnest film in which the reflected light will be a max
The discussion revolves around determining the thinnest film that produces maximum reflected light for monochromatic light striking at normal incidence. The consensus indicates that a film thickness of λ/4 is correct, despite initial confusion regarding the phase shifts at the boundaries. Participants suggest that the problem may have overlooked the 180° phase shift occurring at the air-film interface. There is speculation that the film's index of refraction could influence the expected results. Ultimately, the thinnest film for maximum reflection is confirmed to be λ/4.
Any Help
Monochromatic light, at normal incidence, strikes a thin film in air. If λ denotes the wavelength in the film, what is the thinnest film in which the reflected light will be a maximum?
  • A
    λ/4
  • B
    3λ/4
  • C
    λ
  • D
    much less than λ
  • E
    λ/2
n air ∠ n glass
so at the first reflection it will cuase a 180° ray out of phase while the second ray reflected from the inside it will stay inphase because n air ∠ n glass
so for constructive interference: 2L=odd number*λ/2
least odd number is one , so L=λ/4 ?? why it is incorrect
Your answer of λ/4 is correct. The problem statement does not mention glass.
Likes Any Help
Well all I can do is sympathize. 1/4 should have been correct. Perhaps they have in mind a low index film on a high index substrate? Or perhaps the problem setter forgot about the 180 phase shift front to back and just got it wrong.
Likes Any Help
Any Help said:
the thinnest film in which the reflected light will be a maximum[/color] minimum[/color] ?
possibly intended
Likes Cutter Ketch
