- #1
GreenWombat
- 9
- 2
- TL;DR Summary
- My theory/computer program gives a bigger result than my experiment. I may have the "moment of inertia" wrong.
I am interested in climate change and thereby interested in tipping points. So for the last few months, I have been investigating the dynamics of a toppling brick. I derived a differential equation of for the motion and wrote a computer program to solve this from initial conditions.
I have more detail and a diagram on
https://www.feedbackreigns.net/tipping-points/
Trouble is that my computer output suggests a longer toppling time than my experiment with a brick.
I suspect my moment of inertia may be wrong.
Inertia = M * (W * W + H * H) / 12 + M * R * R
I did a primitive experiment. I used some cut cardboard to give my red brick an initial tilt of 35 degrees from the vertical. Then I let it rotate from rest to the ground (tilt = 90 degrees), recording the sound of this on a mobile phone. It all happens so fast.
The experimental toppling time is about 0.4 or 0.5 seconds.
My calculation is out by about a factor of 6.
My program gives a much larger result.
Block Mass: kilogram = 4.06
Block Height: metre = 0.225
Block Width: metre = 0.104
Brick Depth = 0.075 is not used in my calculations
Initial Tilt from vertical: degrees = 35.0
Initial tilt speed: degrees/sec = 0.0
Radius of motion of Centre of mass: metre = 0.12394
Tipping point Angle: degrees = 24.80745
Initial Tilt past tipping point: degrees = 10.19255
Acceleration of gravity = 9.8
Moment of inertia: kg metre^2 = 0.08315
Acceleration factor = 59.30457
Maximum Tilt: degrees 90.00010
Topple Time: seconds = 2.52319
TiltStep for numerical calculation = 1 degree
Can anyone suggest why I get this discrepancy between theory and experiment?
