The zero state response does not satisfy the diff equation. Why?
The discussion centers on the discrepancy between the zero-state response and the differential equation for a linear system represented by the equation d²y/dt² + 7*dy/dt + 12*y = dx/dt + 5*x. The proposed impulse response h(t) = (-e^(-4*t) + 2*e^(-3*t))*u(t) does not satisfy the equation due to the complexities introduced by the unit impulse function, δ(t), and its derivatives. The analysis reveals that when applying the chain rule, the terms involving δ(t) lead to inconsistencies in the coefficients on both sides of the equation. The discussion emphasizes the importance of careful treatment of the impulse function and its derivatives in differential equations. Ultimately, the impulse response must be verified through integral equations to ensure it aligns with the system's behavior.
logicman112
If we have a linear system(it could be a RLC circuit) with the following differential equation:
d2y/dt2+7*dy/dt+12*y=dx/dt+5*x
So H(s) = (s+5)/((s+4)*(s+3)) = -1/(s+4)+2/(s+3)--> h(t) = (-e^(-4*t)+2*e^(-3*t))*u(t)
(Please calculate the unit impulse response by Laplace transform and verify the result by yourself)
Why this answer(which is Zero-State response) does not satisfy the differential equation?
The right answer is:
h(t) = (-2*e^(-4*t)+3*e^(-3*t))*u(t)
If h(t)=(-e^(-4*t)+2*e^(-3*t))*u(t) is the impulse response, as its
Laplace transform suggests, so it must satisfy
"d2y/dt2+7*dy/dt+12*y=dx/dt+5*x" so(using the chain rule and our input
is the unit impulse function, delta(t) ):
y(t) = (-e^(-4*t)+2*e^(-3*t))*u(t) and x(t) = delta(t)
dy/dt = (4*e^(-4*t)-6*e^(-3*t))*u(t)+(-e^(-4*t)+2*e^(-3*t)) * delta(t)
d2y/dt2 = (-16*e^(-4*t)+18*e^(-3*t))*u(t)+[4*e^(-4*t)-6*e^(-3*t)+4*e^(-4*t)-6*e^(-3*t)]*delta(t)+
(-e^(-4*t)+2*e^(-3*t))*d(delta(t))/dt
d2y/dt2+7*dy/dt+12*y = (-e^(-4*t)+2*e^(-3*t))*d(delta(t))/dt
+ [8*e^(-4*t)-12*e^(-3*t)-7*e^(-4*t)+14*e^(-3*t)]*delta(t)+
[-16*e^(-4*t)+18*e^(-3*t)+28*e^(-4*t)-42*e^(-3*t)-12*e^(-4*t)+24*e^(-3*t))*u(t)=
(4*e^(-4*t)-6*e^(-3*t)) d(delta(t))/dt +
[e^(-4*t)+2*e^(-3*t)]*delta(t)+0*u(t) --->
d2y/dt2+7*dy/dt+12*y = (-e^(-4*t)+2*e^(-3*t)) *d(delta(t))/dt +
[e^(-4*t)+2*e^(-3*t)]*delta(t) = d(delta(t))/dt+5*delta(t)
so the coefficient of delta(t) is 3 in the left side while it is 5 in
the other side! and it seems the equality can not be satisfied.
If (-e^(-4*t)+2*e^(-3*t))*u(t) is the impulse response why it does not
Good question logicman112, and it's answer goes right to the heart of why we must be very careful when using the impulse function, \delta(t).
First off you need to know that the unit impulse function does not exist, it's a useful as a "limiting case" abstraction but it does not actually exist in nature. The only place the impulse function actually makes sense is inside an integral, use it any other way and you'd better be careful.
Now as bad as the unit impulse is it's derivative is infinitely worse. Imagine for example (by way of analogy) you had both sides of an algebraic equation divided by zero. It would be hard to say anything conclusive about the terms in that equation, right? Same thing with your equation that has derivatives of delta functions on both sides, it means you have to re-consider what you're doing and how you're doing it.
I suggest you look at the following integral equation and confirm that your proposed impulse response does indeed work correctly.
\frac{dy}{dt} + 7 y + 12 \int_{0}^{t} y(\lambda)\,d\lambda \,=\, x + 5 \int_{0}^{t} x(\lambda)\,d\lambda
It's easy to show that the LHS and RHS of the above are equal for x(t) = \delta(t) and y(t) =2 e^{-3t} - e^{-4t} \,\, : \, x>0, \, \left\{ y(t)=0 \,\,:\, x<0 \right\}.
Thanks uart. As you wrote, it seems that the chain rule of derivatives becomes false for f(t)*delta(t)
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
