How Does cos(θ)sin(θ+φ)-sinθcos(θ+φ) Simplify to sinφ?
The discussion revolves around simplifying the expression cos(θ)sin(θ+φ) - sinθcos(θ+φ) to sinφ using trigonometric identities. Participants suggest using the sine addition formula, sin(u+v) = sin(u)cos(v) + cos(u)sin(v), to aid in the simplification. The key step involves recognizing that the expression can be rewritten as sin(θ + φ - θ), which simplifies directly to sinφ. There is also mention of substituting identities for sin²(θ) and cos²(θ), but the most straightforward approach is highlighted. Ultimately, the simplification confirms that the expression equals sinφ.
leaf
Can someone please show me, step-by-step, how
simplifies to sinφ?
I know I have to use trig identities, and I got to cos2θsinφ-sin2θcosφ but I'm not sure where to go from there.
Thanks
Mathematics news on Phys.org
have you tried the ##sin^2\theta + cos^2\theta = 1## ?
Yeah, if I substitute for both I get:
sin(\phi)-sin^2(\theta)sin(\phi)-cos(\phi)+cos^2(\theta)cos(\phi)
But I should probably only substitute for sin or cos so that gives me:
sin(\phi)-sin^2(\theta)sin(\phi)-sin^2(\theta)cos(\phi)
or
cos^2(\theta)sin(\phi)-cos(\phi)+cos^2(\theta)cos(\phi)
but I'm still not sure where to go from here.
sin(u+v) = sin(u)cos(v)+sin(v)cos(u). Also sin(-u) = -sin(u).
Likes leaf and jedishrfu
simplifies to sinφ?
Thanks
Maybe someone else already told you but you can use the next identity
sin(u+-v) = sin(u)cos(v)+-cos(u)sin(v)
if oyu compare it with you homework then the answers is:
sin(θ+φ-θ)=sinφ
Likes leaf
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
