Theoretical Question: Is W = PE?
  • Thread starter Thread starter Goldenwind
    Theoretical
The discussion explores the relationship between work (W) and potential energy (PE), questioning if W equals PE under certain conditions. It establishes that both work and potential energy involve mass and distance but emphasizes that W is dependent on the angle between force and displacement. The conclusion drawn is that while work can lead to changes in kinetic and potential energy, they are not inherently equal. Additionally, the similarity in units of work and energy does not imply a direct conceptual relationship. Ultimately, the conversation highlights the complexity of energy transformations in physics.
Goldenwind
This isn't a homework question, just something I was pondering one day.
W = Fd = mad
PE = mgh
m = m, obviously
g and a are both measurements of acceleration
h and d are both measurements of distance
If g = a, and h = d, is it fair to say that W = PE?
Therefore, W = a change in KE, so PE = Change in KE?
W = Fd = mad
PE = mgh
m = m, obviously
Not quite. The work done on an object can result in a change in kinetic and/or potential energy. In order for W to be equal to KE, the accelerating force would have to be at right angles to the direction of the gravitational force.
The correct equations are:
PE = mgh
W = \vec F \cdot\vec d = m\vec a \cdot\vec d = mad\cos\theta
ie. h would be 0 and \cos\theta would be 1.
AM
W = Fd = mad
PE = mgh
m = m, obviously
All you can really show by this argument is that work and energy have the same units; this does not let us conclude anything at a deeper conceptual level by itself. You'll run into a more extreme case of this when you study torque: you'll learn that torque and energy have the same units but are not much related at all.
