Thermal energy problem: Gas expansion in cylinder
The problem involves a vertical heat-insulated cylinder divided by a movable piston, with one side containing a monatomic gas at a specified temperature. The scenario describes the gas's behavior when the piston is released, leading to a change in volume and a query about the final temperature of the gas.
  • Exploratory, Assumption checking
  • Participants discuss the relationship between pressure and the weight of the piston, questioning the validity of using the equation mg = PA. There is mention of the adiabatic nature of the process and the use of relevant equations such as PV = nRT and the concept of heat capacity ratios.
The discussion includes attempts to clarify the assumptions regarding the adiabatic process and the implications for the final temperature. Some participants have expressed confidence in their calculations, while others have acknowledged the importance of understanding the process dynamics.
There is an emphasis on the adiabatic condition of the system, with participants noting that no heat transfer occurs during the process. This aspect is critical to the problem's interpretation and solution approach.
Bonapartist
A vertical heat-insulated cylinder is divided into two parts by a movable piston of mass m. Initially, the piston is held at rest. The top part is evacuated and the bottom part is filled with 1 mol of monatomic gas at temperature 300 K. After the piston is released and the system comes to equilibrium, the volume occupied by the gas is halved. Find the final temperature of the gas.
PV = nRT
S = Q/T
mg = PA?[/B]
I've attempted to solve this problem using the fact that mg = PA and that the pressure can be solved for. Is this incorrect?
Thanks! As the first time I've posted on PF, I am delighted to be a contributing member!
PV = nRT
S = Q/T
mg = PA?[/B]
Considering the process is adiabatic(ideally insulated q=0, no heat transfer involved in the process), use PVk=const or P1V1k=P2V2k
k is just the heat capacity ratio of the gas given k=Cp/Cv
I've solved it to be 476.22 K, a reasonable answer. Thanks for pointing out its adiabatic nature!
Your welcome.
  • · Replies 67 ·
  • · Replies 33 ·
12K
