Thermal Expansion of thermometer in ice water
The discussion centers on calculating the temperature of a solution using the length of a mercury column in a thermometer. Initially, the user calculated the length at room temperature to be 8.23 cm, which was confirmed correct. However, they struggled with determining the temperature corresponding to a 25.2 cm mercury column, initially arriving at incorrect values of 107.23°C and 129.23°C. After guidance, they realized their method needed adjustment and correctly calculated the temperature to be 108.72°C. The conversation highlights the importance of understanding the relationship between mercury column length and temperature in thermometers.
S_fabris
Here is a two part problem I'm having trouble with:
The length of the column of mercury in a thermometer is 4cm when the thermometer is immersed in ice water and 23.5cm when the thermometer is immersed in boiled water.
a) What should be the length at room temperature 22degreesCelcius?
I did ratio calculation to find this and got 8.23cm and it was correct
Here is where I'm stuck:
b) if the mercury column is 25.2cm long when the thermometer is immersed in a chemical solution, what is the temperature of the solution (answer in deg.Celsius)
Again i tried doing a ratio: 100degC = 23.5cm
xdegC = 25.2cm
my answer was 107.23degC and I is incorrect...though it makes sense and seems correct to me logically...I'm not really sure where to go from here any advice?:confused: :confused:
Sergio
Try converting the degrees to Kelvin and see if that works.
Edit: I seem to recall an expansion formula such as L=Li*alpha*(T2-T1) where L is the initial length and Li is the length by which it changes. Alpha is a constant. Maybe try solving for T2. Don't know if this is right though.
Not sure what you mean by ratio.
23.5cm - 4cm = 19.5cm over 100 C, so each 1 C division is 0.195cm. Go from there
If I use this information...
0.195cm = 1 C
25.2cm = x C
so 0.195(x) = 25.2(1)
x = 25.2/0.195
x = 129.23 C (incorrect)
that what i meant by "ratio" (i study in French don't know English terms that well :P)
so so far i know that 129.23C and 107.23C are incorrect :S
(25.2cm - 23.5cm) = 1.7cm, you just need to work out how many degrees C 1.7cm represents. You then add this to 100 C ( the temperature at 23.5cm)
Your method is 'wrong' because the x=0cm doesn't represent T = 0 C it represents x= 4cm, T= 0 C.
Thanks for clearing this up for me Max (and your patience)
Something just wasn't clicking i guess...i got the correct answer at 108.72C :D
Thx again :)
