How Hot Must the Steel Rim Be to Fit Over the Cast Iron Wheel?
Nai
The question is : Wheels for railway cars are made of a disk shaped cast iron body of outer diameter 930.0 mm and a steel rim of inner diameter 927.0 mm at 20 degrees Celsius. To what temperature must the steel rim be heated so that it will just slip over the cast iron body?
I know we use the linear expansion formula which is :
The change of length=alpha(initial length)( change of temperature)
The alpha would be the coefficient of linear expansion in this case would be the steel's coefficient which is 1.3e-5 K^-1.
I don't think it's possible to get 268.9 degrees for the steel to expand o-o
My work:
(930-927)=(1.3e-5)(927)(T-20)
T=268.9 degrees Celsius
I think I'm doing something wrong >___<
If anyone could help me, it would be awesome.
Thank you in advance.
I don't think it's wrong. An expansion of 3mm is quite big. The answer is still far away from the melting point of iron (~ 1500 Celsius degrees)
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
