Thermal radiation experiments
In summary, the book says that in a solid, the atoms are arranged in a lattice with tight bonds. This means that when considering the three heat transfer mechanisms, conduction, convection and radiation. Convection is characterized by fluid motion transporting hotter parts of the fluid along gravity induced pressure gradients, and radiation is usually small. However, when other objects are not in contact with the "hot" object, radiation becomes large.
Telemachus
835
30
Hi there. Here is the deal. In my lab work, I've done experiments concerning on heat conduction. Now my professor had corrected my inform, and asked me a question for which I have no answer. I consulted for my work the book "heat conduction in solids" by H.S. Carslaw.
The book says at the introduction:
"When different parts of a body are at different temperatures heat flows from the hotter parts to the cooler. There are three distinct methods by which this transference of heat takes place: (i) Conduction, in which the heat passes through the substance of the body itself, (ii) Convection, in which heat is transferred by relative motion of portions of the heated body, and (ill) Radiation, in which heat is transferred direct between distant portions of the body by electromagnetic radiation.
In liquids and gases convection and radiation are of paramount importance, but in solids convection is altogether absent and radiation usually negligible. In this book we shall consider Conduction of heat only, and usually speak of the body as solid, though in crtain circumstances the results will be valid for liquids or gases. In this chapter the general theory of conduction of heat is developed; the subsequent ohapters are devoted to special problems and methods.
I've subtracted from it the bold part. And my professor asked my, why is it negligible? and I don't know how to answer this, I've been investigating, and I get to the black body, and Planck's law, it doesn't seem like the answer I'm looking for this work, it actually seems to be like a topic for an entire different work. So I don't know what to do, or how to justify this sentence. I think that it is negligible for the temperatures we've been working in the lab, but for temperatures near the fusion point the radiation would be more and more significant with increasing temperature.
Perhaps you can help to understand a bit more on thermal radiation, or point me some work or book on this topic, so I can justify correctly what I said in my inform.
Thats all.
Bye there.
Hi There,
I will firstly say I am no expert in this field but your statement:
It is my understanding that in a solid, the atoms are arrange in a lattice with tight bonds. Therefore when considering the three heat transfer mechanisms, conduction, convection and radiation. Convection is characterized by fluid motion transporting hotter parts of the fluid along gravity induced pressure gradients , therefore in a solid where the lattice is rigid, convection heat transfer will be negligible.
The radiation contribution to heat transfer is in general much smaller than the other terms (I believe this can be shown but I forget how!) However it is when other objects are not in contact with the "hot" object that the radiation term becomes large (such as a radiator). This is because the electromagnetic radiation does not suffer the same losses with distance as conduction.
Therefore the only term with a significant contribution in the conduction.
This is an interesting post, I would also like to know the answer. What about lasers burning holes in solids?
I didn't mention it, but the part I must justify is why the radiation is negligible. I think it's negligible under certain condition that I should specify more clearly, conditions that my experimental work fits (the slab bar with different boundary conditions, I used an electric soldering to heat one extreme).
For example, in the soldering it self, radiation doesn't seem that negligible, one can "feel it" putting a finger close to it. I think that not necessarily the object must be "separated" from the source of heat to consider radiation, but perhaps you're right, I'm not sure. What I'm trying to say is that one could consider in the experiment looses in heat due to radiation, and the bar was isolated (so radiation could be important under other conditions). For example, a heated iron red colored it's radiating an important amount of heat I think, and it looks like it radiates more and more while you're heating it, and the extreme case would be when you have a plasma, but then it's not a solid anymore, but I think it illustrates an increasing radiation with temperature. However, as closer you are to the melting point radiation becomes more important for the iron case I think, but this is not something general, for example water doesn't behave this way.
Thanks for your answers, I'd really like to discuss a bit this thing.
Bye and sorry for my awful english.
Hello there. Thank you for sharing your experience and question. It is great that you are seeking clarification and understanding in your lab work. Thermal radiation is a very important topic in the study of heat transfer, and it is important to have a solid understanding of it in order to accurately interpret experimental results.
To answer your professor's question, the reason why thermal radiation is usually negligible in solids is because the emission of electromagnetic radiation is dependent on the temperature difference between two objects. In solids, the molecules are closely packed together and have strong bonds, so the temperature difference between different parts of the solid is usually very small. This leads to a low emission of thermal radiation. Additionally, solids are opaque to thermal radiation, which means that it is difficult for heat to escape through radiation.
However, as you mentioned, at very high temperatures, such as near the fusion point, the emission of thermal radiation becomes more significant. This is because the temperature difference between different parts of the solid is larger, and the bonds between molecules may weaken, allowing for more heat to escape through radiation.
To justify the statement in your report, you can mention the factors that contribute to the negligible amount of thermal radiation in solids, such as the close packing of molecules and the opacity to radiation. You can also mention that at higher temperatures, the contribution of thermal radiation becomes more significant. Additionally, you can refer to other sources or studies that support this concept.
Some additional resources that may be helpful in understanding thermal radiation are "Thermal Radiation Heat Transfer" by Siegel and Howell, and "Introduction to Heat Transfer" by Incropera and DeWitt. I hope this helps and good luck with your research.
1. What is thermal radiation?
Thermal radiation is the process by which heat is transferred from one object to another through electromagnetic waves. These waves are a type of energy and can travel through a vacuum, unlike conduction or convection which require a medium to transfer heat.
2. How do thermal radiation experiments work?
Thermal radiation experiments involve using specific materials and equipment to measure the amount of thermal radiation emitted by an object or surface. This can include using a spectrometer to measure the wavelengths of the radiation or using a thermal camera to visualize the heat distribution.
3. What are some common applications of thermal radiation experiments?
Thermal radiation experiments are used in a variety of fields such as materials science, environmental science, and engineering. They can be used to study heat transfer in different materials, measure the thermal properties of buildings, and even monitor changes in the Earth's climate.
4. What are the potential hazards of conducting thermal radiation experiments?
One of the main hazards of thermal radiation experiments is exposure to high levels of heat or radiation. It is important for scientists to take proper safety precautions and use protective equipment, such as goggles and gloves, when working with high heat or radiation sources.
5. How do scientists measure and quantify thermal radiation?
Scientists use a unit called a watt per square meter (W/m²) to measure and quantify thermal radiation. This unit represents the amount of energy transmitted over an area in one second. Additionally, scientists can use special instruments, such as pyrometers, to measure the intensity and wavelengths of thermal radiation.
  • Thermodynamics
  • Thermodynamics
