Thermo question (Compressor w/ cooling fluid)
The discussion centers on a homework assignment involving a control volume analysis of a cooling stream and condensed fluid. The user assumed zero heat generation and net work, leading to a calculated mass flow rate of 4484.5 Kg/s, which they found unreasonable. Other participants confirmed that assuming net work is zero is acceptable and noted that a high mass flow rate is expected due to significant energy changes in nearly saturated vapor. The consensus suggests that the assumptions made are valid for this type of analysis. The conversation highlights the complexities of thermodynamic calculations in cooling systems.
mxpxer7
I attached the HW assignment. Its question number 2.
I choose a control volume including the cooling stream from the lake and the fluid being condensed. I assumed with this CV that the heat generated was 0 and that the net Work was 0.
Using these assumptions I solved for the mass flow rate and I got a number that seemed totally unreasonable... M= 4484.5 Kg/s .. Anyone have any suggestions?
is it okay to assume the net work is 0?
All of your assumptions seem correct and I got very close to the same answer that you did. A high mass flow rate in the cooling fluid is to be expected to cause such a tremendous energy change in a high speed mass flow rate of an almost completely saturated vapor.
