Thermochemistry Problem: Heat Transfer in the Reaction of Sulfur and Oxygen
In summary, Tom Mattson calculated that 0.017 mol of SO3 would be produced when 0.54g of sulfur reacts with 0.54g of oxygen, but the teacher provided the correct answer which is that 0.011 mol of SO3 would be produced.
TbbZz
37
How much heat will be transferred when 0.54g of sulfur reacts with 0.54g of oxygen to produce sulfur trioxide according to the following reaction:
2 S (s) + 3 O2 (g) --> 2 SO3 (g)
change in Enthalpy = -790kJ
First, I reduced the equation:
S + 3/2 O2 --> SO3
change in Enthalpy = -395 kJ/mol
Second, I figured out the limiting reactant:
0.54g x (mol/32.07g) = 0.017mol x (3 mol O2 / 2 mol S) = 0.0253 mol O2
0.54g O2 x (mol/32g) = 0.017mol x (2 mol S / 3 mol O2) = 0.0112 mol S
Third, I took the limiting reactant, 0.0112 mol S, and did:
0.0112 mol S x -395kJ = 4.42kJ
So my answer is 4.42kJ. However, this answer was incorrect. Would anyone be able to guide me to the correct answer? Thanks!
When determining the limiting reactant, you are supposed to calculate the amount of product that results by the complete consumption of each reactant separately. That means that you shouldn't be doing stoichiometric calculations with S and O2. Rather, you should be doing calculations to determine how much SO3 each reactant can produce.
According to my calculation, O2 is the limiting reactant.
Okay, so how does this look?
0.017 mol S ---- which produces 0.017 mol SO3
0.017 mol O2 ---- which produces 0.011 mol SO3
Therefore, the 0.017 mol O2 is the limiting reactant because using all 0.017 mol O2 only produces 0.011 mol SO3.
What exactly do I do next?
Thanks.
You want to know the enthalphy change that results from using 0.54 g of O2, and you know the enthalpy change that results from using 3 mol of O2. Seems pretty straightforward, does it not?
I am probably making a silly mistake, but for some reason, I am still getting -4.47kJ as my answer.
0.017 mol O2 x ( -790kJ / 3 mol O2 ) = -4.47 kJ
Thanks again for the assistance, Tom Mattson.
Are you submitting your answers into some computer grading system? If so, then maybe it's just being picky. My calculation disagrees with yours in the hundredths place.
[tex]0.54gO_2\times\frac{1molO_2}{32gO_2}\times\frac{-790kJ}{3molO_2}=-4.44375kJ[/tex]
This was a quiz in real life. The teacher provided us with the work and answer for each problem. I uploaded the work and answer for this particular problem in an image file:
Your teacher is wrong. At the top of the paper he is treating S as though it were the limiting reactant. It isn't.
Tom Mattson, I greatly appreciate the speedy and helpful assistance, I will inquire about this question from the teacher.
1. What is thermochemistry?
Thermochemistry is the branch of chemistry that deals with the study of the heat energy changes that occur during chemical reactions and physical processes.
2. How do you solve a thermochemistry problem?
To solve a thermochemistry problem, you need to first identify the type of reaction or process involved, then use the appropriate equations and values to calculate the heat energy change (enthalpy) of the reaction or process. This involves using the standard enthalpies of formation or the bond energies of the reactants and products.
3. What is the difference between exothermic and endothermic reactions?
An exothermic reaction releases heat energy to its surroundings, resulting in a negative change in enthalpy. On the other hand, an endothermic reaction absorbs heat energy from its surroundings, resulting in a positive change in enthalpy.
4. How does temperature affect thermochemistry?
The temperature affects thermochemistry by influencing the rate of a reaction or process, as well as the amount of heat energy absorbed or released. Higher temperatures generally result in faster reactions and greater heat energy changes.
5. What are some real-life applications of thermochemistry?
Thermochemistry has various real-life applications, including in the production of energy from fuels, the design of refrigeration and air conditioning systems, and the study of metabolic processes in living organisms. It is also crucial in the manufacturing of pharmaceuticals, plastics, and other industrial products.
  • Biology and Chemistry Homework Help
