Thermodynamic Process: Is Work Conserved?
The discussion centers on the calculation of work done during a thermodynamic cycle involving isobaric and isothermal processes. The derived formula for work from B to C is WBC = p1(V2 - V1), which raises questions about its validity. Participants confirm that the change in internal energy for the entire cycle is zero, as the initial and final states are identical. They also highlight that for isothermal processes, the internal energy change is zero, while for isobaric processes, it can be calculated based on the type of gas. Overall, the logic presented in the calculations is deemed correct, but the complexities of thermodynamic cycles are acknowledged.
Ian Baughman
What is wrong with this logic, if any? It does not seem like this should be true but maybe I'm mistaken.
Assuming the process consists of two isobaric processes and two isothermal processes the work from B to C in terms of p1, p2, V1, and V2 is given by the following.
1) WBC=p2(VC-VB)
2) Isothermal from A → B so p1V1 = p2VB so VB=(p1V1)/p2
3) Similarly VC=(p1V2)/p2
4) WBC= p2((p1V2)/p2-(p1V1)/p2)
5) Factor out p1/p2 and simplify the you get;
WBC=p1(V2-V1)​
Likes Charles Link
Science news on Phys.org
1) WBC=p2(VC-VB)
WBC=p1(V2-V1)​
The isothermal processes have no change in internal energy. for an ideal gas. Much heat must be added to the system in the isobaric expansion for two reasons: 1)work is being done as it expands 2) It is going to a higher temperature state. In the isobaric compression, much heat must be removed from the system for two reasons 1) The system is going to a lower temperature 2) Work is being done on the system. The energy from this work must also be removed by removing heat. I do think your calculations are correct. Thermodynamic problems can sometimes be tricky, but I believe you analyzed it correctly.
Likes Ian Baughman
It should also be noted that you can readily compute ## \Delta Q=\Delta W ## for each of the two isotherms, since each has ## \Delta U=0 ##. ## \\ ## Meanwhile ## \Delta U ## for each of the isobars will be ## \Delta U=\frac{3}{2}nR \Delta T ## for an ideal monatomic gas, and ## \Delta U=\frac{5}{2}nR \Delta T ## for an ideal diatomic gas (where ## \Delta T=\Delta (PV)/(nR) ##). You can thereby readily compute ## \Delta Q ## for each of the isobars, if you know the type of gas. ## \\ ## I think I have this completely correct, but it's always good to have someone double-check the solution. @Chestermiller Did we get everything correct?
Since this is a thermodynamic cycle with the final state being identical to the initial state would the total change in internal energy be equal to zero?
Yes. And if you will notice, for the two isotherms ## \Delta U=0 ## and for the transitions on the two isobars, ## \Delta U_1=-\Delta U_2 ##. ## \\ ## Editing... perhaps we haven't proved yet that ## \Delta (PV) ## is equal and opposite for these two cases...but that is obvious because on one isotherm, ## PV=nRT_1 ## and on the other isotherm ## PV=nRT_2 ##.Thereby ## \Delta (PV)=nR \Delta T ## and ## \Delta U=\frac{3}{2} nR \Delta T ## or ## \Delta U=\frac{5}{2} nR \Delta T ##.
1) WBC=p2(VC-VB)
WBC=p1(V2-V1)​
Yes. So...
And yes, since this a thermodynamic cycle, the change in internal energy for the working fluid has to be zero.
Likes Charles Link
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
