etotheipi
Just to clarify, I'm aware of the two equivalent expressions of the first law ##\Delta U = Q + W## and ##\Delta U = Q - W## when applied to a certain system, though my question is primarily about ##Q## - for which, as far as I am aware, the convention is almost universally that ##Q > 0## if heat is transferred to the system.
Firstly, suppose we have a heat engine operating between ##T_h## and ##T_c##. On a diagram, and in calculations, we'd usually write that ##Q_h## is transferred from the source to the engine and ##Q_c## from the engine to the sink. We might then define other quantities like ##\eta = \frac{Q_h - Q_c}{Q_h}##, except clearly this doesn't obey the sign convention. Because if we stick to it, then ##Q_c## is negative and we should really write ##\eta = \frac{Q_h + Q_c}{Q_h} = \frac{Q_h - |Q_c|}{Q_h}##. Also, on heat engine diagrams, we generally label the arrow from the engine with the sink with ##Q_c##. Though should we be writing ##Q_c## or ##-Q_c##?
And on a sort of related note, often we will want to know the heat given out to the surroundings (e.g. maybe for calculating an enthalpy change of a reaction). Is it good practice to "reverse" the system and surroundings in this case? That is, we might first define the system to be the reactants, which have heat ##Q## transferred to them. Then, we let the previous surroundings be the new system, and the reactants the new surroundings, and now we may say ##-Q## is the heat transferred to the surroundings. Is the "reversing" part necessary? I ask because it seems somewhat dubious to refer to the heat transferred to the surroundings, since our sign convention is defined for the system!
Thank you!
Thank you!
