Thermodynamics: (Entropy) Multiplicity using hypercube
The discussion centers on the calculation of multiplicity using hypercube (n-cube) in the context of thermodynamics and entropy. The original poster sought a specific Wikipedia link related to this topic but struggled to find it. They later identified that the information was located on the Gibbs paradox page. The link provided is https://en.wikipedia.org/wiki/Gibbs_paradox. This highlights the importance of specific terminology in academic searches.
MalveAC
Hello,
Few years back I was reading about calculating multiplicity using hypercube (n-cube). Multiplicity was normalized using this method. I wanted to read it again but I just cannot find it now. I tried every combination of keywords. I remember it was a Wikipedia link. Any help would be highly appreciated.
Thanks!
Science news on Phys.org
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
