Thermodynamics Fun: Is Net Work = Change in Q for Brayton Cycle?
  • Thread starter Thread starter sportsrules
    Fun Thermodynamics
In a Brayton cycle using helium gas, the relationship between net work and change in heat (Q) is debated. While some argue that the first law of thermodynamics implies net work equals change in heat, others clarify that a Brayton cycle is not an isolated system, making this equality unlikely. The first law states that the change in internal energy (ΔU) equals the heat added (q) plus the work done (w), but this does not directly apply to non-isolated systems. Calculating work and heat through the cycle's four steps is essential for understanding the dynamics involved. Overall, the net work and change in heat are not expected to be equal in a Brayton cycle.
sportsrules
For a brayton cycle on a pressure and temperature diagram, using helium gas, is it reasonable to have the net work for the cycle and the change in Q for the cycle to come out to be equal to each other?
i thought the first law of thermodynamics said "change in work is equal to change in heat"
so yeah it is reasonable. and i just worked some brayton cycle problems for homework, and yeah that's what i had
First law of Thermodynamics
\Delta U = q + w
Or in differential form
dU = dq + dw
In an ISOLATED system, \Delta U = 0. A Brayton cycle, however, is not isolated. Actually its not even closed. So offhand I would not expect the net work to be the same as the net heat evolved. I would however, calculate the work done and heat evolved through all 4 steps of the cycle for an ideal gas. You have two isobars and two isoentropes (constant entropy).
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
