Thermodynamics: Internal Energy
naspri4
I need some help on these problems, i got most of the other problems right, but these ones I am not sure what to do with. I don't even know if those are the right equations for it. Someone please help.
1. A cylinder-and-piston containing an ideal gas is placed in contact a thermal reservoir. The volume of the gas is very slowly changed from 50 liters to 12 liters as 50 J of work is done on it by an external agency. Determine the change in the internal energy of the gas.
The answer is in Joules
1.2. Determine the change in the amount of heat flowing into or out of the system. (For reference, a negative value of heat means it is flowing out of the system.)
the answer is in Joules
2. A gas in a thin plastic bag at atmospheric presure receives 10480 J of heat and, in the process, puffs up the bag, increasing its volume by 0.90 m3. By how much is the internal energy of the gas altered?
the answer is in kJ
3. Heat is added to 4.00 m3 of helium gas in an expandable chamber that thereupon increases its volume by 2.00 m3. If in the process 2.22 kJ of work are done by the gas, what was its original pressure?
the answer is in kPa
change in energy=W
change in energy=W+Q
change in energy=W+Q+Em
1.2. 88-50
2.(10480)(.9)
3.?
Hi naspri4, welcome to PF. One serious problem I see is that you're not making sure your units match. For example, your first answer combines Joules with liters, which can never be right.
I agree with using the equation \Delta U = W + Q for change in energy. The problem is that both \Delta U and Q or W are sometimes unknown. There's also another equation you'll need that connects internal energy to temperature for an ideal gas, and that should be enough to solve these problems.
naspri4 said:
I need some help on these problems, i got most of the other problems right, but these ones I am not sure what to do with. I don't even know if those are the right equations for it. Someone please help.1. A cylinder-and-piston containing an ideal gas is placed in contact a thermal reservoir. The volume of the gas is very slowly changed from 50 liters to 12 liters as 50 J of work is done on it by an external agency. Determine the change in the internal energy of the gas.
If the gas is in contact with a thermal reservoir and it is compressed slowly, what can you say about the temperature of the gas during the process?
Use the answer from the first to determine the heat flow (is it out of or into the gas?).
the answer is in kJ
I think the question must be wrong because the work done exceeds the heat input by about 9 times.
I think you have to assume that the pressure is constant here.
AM
Ok, so for the first question, the temperature would be constant meaning there wouldn't be any change. So how would that help me solve the problem? Did I have my equation set up right at the bottom of the first thread. I tried emailing my teacher via webassign but he has not responded for some unknown reason.
The second one was correct being zero, i don't know how but it was.
What about the third question? Any tips on how to solve it?
Apply the first law. If there is no change in U what is the relationship between Q and W?
The work done is 101KPa x .9 m^3 =91KJ. If there is a heat flow of only 10.480 KJ this can't happen.
If pressure is constant, what is the relationship between Work and total change in volume?
AM
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
