Thermodynamics is air ducts, dew point
The airflow inside an air conditioning duct, particularly when cooled, behaves more like constant pressure rather than constant volume. This is important for accurately determining the dew point of the air flow. While there is a small pressure differential created by the fan, it is negligible in the context of the overall airflow. Therefore, for practical purposes, assuming constant pressure is a valid approximation. Understanding this distinction is crucial for HVAC system analysis and performance evaluation.
rolan91602
Can anyone confirm if the flow of air inside an air conditioning duct, when cooled, behaves as constant volume as compared to constant pressure? I am trying to determine the dew point of the flow and, depending of how it behaves inside the duct, this value will depend on if it is at constant voulume or constant pressure. I think it is at constant volume. Please confirm.
Science news on Phys.org
The duct is open on both ends. There is going to be a small pressure differential due to the fan, required to move the air, but it's going to be almost insignificant. To a good approximation, you can assume constant pressure.
Thank you.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
