Thermodynamics Problem: Calculating Mass of Lead and Water in Equilibrium
In summary, the conversation discusses a physics problem regarding the transfer of heat between molten lead and water. The problem involves calculating the mass of lead and water remaining in an insulated bucket after they reach thermal equilibrium. The conversation also discusses the phase transitions of the lead and water and mentions the boiling and melting points. The final answer is obtained by taking into consideration these phase transitions.
chipM
Not sure if this is the right thread for this question but here goes :
A worker pours 1.25 kg of molten lead at a temperature of 327.3 into 0.500 kg of water at a temperature of 75 C in an insulated bucket of negligible mass. Assuming no heat loss of the surroundings. Calculate the mass of lead and water remaining in the bucket when the materials have reached thermal equilibrium.
C(water)=4190
C(lead ) = 130
Q=mcdelta T
(1.250)(130)(600.3-t)= Q (lead)
(1.250)(4.19)(T-348)=Q(water)
expand rearrange :
97500-162.5T=5237.5T-1822650
T= 355.57333
i kind of lost here , that's all i have done
the answear is
(1.743kg) - remember, steam will be produced!
but how is this the answear can someone show me the working ?
thanks
What happens to water when it reaches a temperature of 100 C? Hint: think teapot.
boiling point of water ? .
but how is the mass achieved ?
You have used the mass of lead (1.25 kg) instead of the mass of water (0.500 kg) in writing the equation for the amount of heat received by the water.
Start out by assuming that not all the water boils away, but that there is enough heat in the lead to raise the temperature of the water to its boiling point. Under these circumstances, what is the final temperature of the lead and water?
Take into consideration that the melting point of lead is 600 K (327.3oC) so the lead must go a phase transition to solid
Lead changing to water or vice-versa? Alchemy perhaps?
If all that's left is lead and water then steam must count as water ...
Or maybe lead oxidizes or ... ?
The problem states "molten lead at 327.3 oC"
My textbook has the melting point of lead to be 600.3 K. A phase transition (liquid to solid) for the lead is necessary, as well as phase transition from liquid to vapor for some of the water.
From where are you coming with an alchemy reference?
The quoted "answer" is obtained when the phase transitions are taken into consideration.
The mass of lead obviously doesn't change, so 50% of the answer is a no-brainer if there ever was one. It starts and ends at 1.25 kg. Easy, huh?
If we decide not to call steam "water" then obviously one can ask for the proportion of water to steam. The problem should have been stated as "what is the remaining proportion of water to vapor".
Alchemy is the changing of one element to another, which would have to happen if the mass of lead were to chage - unless, as I said, we consider chemical reactions like oxidation.
Related to Thermodynamics Problem: Calculating Mass of Lead and Water in Equilibrium
1. What is thermodynamics?
Thermodynamics is a branch of physics that deals with the study of heat, energy, and their relationship to other forms of energy. It explains how energy is transferred and transformed within a system, and how these processes can be quantified and predicted.
2. What is a thermodynamics problem?
A thermodynamics problem is a question or scenario that involves the application of thermodynamics concepts and equations to solve for unknown variables or to analyze a system. These problems typically involve the study of heat, temperature, and energy transfer in various systems and situations.
3. What are the laws of thermodynamics?
The laws of thermodynamics are fundamental principles that govern energy and heat transfer processes. The first law states that energy cannot be created or destroyed, only transferred or transformed. The second law states that in any energy transfer or transformation, some energy will always be lost as heat. The third law states that it is impossible to reach absolute zero temperature.
4. How do you solve a thermodynamics problem?
To solve a thermodynamics problem, you must first identify the known and unknown variables, and then apply the appropriate thermodynamics equations and principles to solve for the unknowns. It is important to carefully analyze the given information and apply the correct equations, taking into account any assumptions or simplifications that may be necessary.
5. What are some common applications of thermodynamics?
Thermodynamics has many practical applications in various fields, including engineering, chemistry, and biology. Some common examples include the design of engines and power plants, refrigeration systems, and chemical reactions. It is also used to study and understand natural phenomena such as weather patterns and energy transfer in living organisms.
