Thermodynamics heat absorption problem
In summary, to change 2-kg of ice at -5°C to steam at 110.0°C, you will need to calculate five heat terms using the given specific heats and heat fusion of ice and heat of vaporization of water. The total heat input will be in Joules.
panther7
How much heat is absorbed in changing 2-kg of ice at -5°C to steam at 110.0°C? The Specific heats of ice, liquid water, and steam are, respectively, 2060 J/Kg x K, 4180 J/Kg x K, and 2020 J/Kg x K. The heat fusion of ice is 3.34 x 10^5 J/Kg. The heat of vaporization of water is 2.26 x 10^6 J/kg
Q=mHf
Q=mHv
Q=mC(change in temp)
You have all the information and formulas you need. Consider that you have five stages that the water has to go through in this process:
the ice must warm up from -5º C to 0º C ;
the ice must then melt into (liquid) water at a constant 0º C ;
the meltwater must now warm from 0º C to 100º C ;
the water must next vaporize into steam at a constant 100º C ; and, finally,
the steam must heat up from 100º C to 110º C .
So you will have five heat terms to compute, using the given information (they were nice to you and didn't even make you do unit conversions). You will get a total heat input in Joules.
I would first identify the key information and variables provided in the problem. The mass of the substance (2 kg) and the temperatures (-5°C and 110.0°C) are given, as well as the specific heats and heat fusion and vaporization values for ice and water. These values will be crucial in solving the problem.
Next, I would use the equations Q=mHf and Q=mHv to calculate the heat absorbed in changing the ice to water and the water to steam, respectively. Using the given values, I would plug them into the equations to get:
Q1 = (2 kg)(3.34 x 10^5 J/kg) = 6.68 x 10^5 J
Q2 = (2 kg)(2.26 x 10^6 J/kg) = 4.52 x 10^6 J
Then, I would use the equation Q=mC(change in temp) to calculate the heat absorbed in raising the temperature of the water from 0°C to 110.0°C:
Q3 = (2 kg)(4180 J/Kg x K)(110.0°C - 0°C) = 9.18 x 10^5 J
Finally, I would add all three values to get the total heat absorbed:
Qtotal = Q1 + Q2 + Q3 = (6.68 x 10^5 J) + (4.52 x 10^6 J) + (9.18 x 10^5 J) = 6.19 x 10^6 J
Therefore, the total heat absorbed in changing 2-kg of ice at -5°C to steam at 110.0°C is 6.19 x 10^6 J.
Related to Thermodynamics heat absorption problem
1. What is the basic principle of thermodynamics?
The basic principle of thermodynamics is that energy cannot be created or destroyed, but can only be transferred or converted from one form to another.
2. What is heat absorption in thermodynamics?
Heat absorption in thermodynamics refers to the process of a substance or system gaining thermal energy from its surroundings. This can occur through various mechanisms such as conduction, convection, and radiation.
3. How does the first law of thermodynamics relate to heat absorption?
The first law of thermodynamics, also known as the law of conservation of energy, states that the total energy of a closed system remains constant. This means that the amount of heat absorbed by a system must equal the amount of work done by the system plus any change in internal energy.
4. What factors affect heat absorption in a system?
The amount of heat absorbed by a system depends on several factors, including the specific heat capacity of the substance, the temperature difference between the system and its surroundings, and the type of heat transfer mechanism involved.
5. How is heat absorption measured in thermodynamics?
In thermodynamics, heat absorption is typically measured in units of joules (J) or calories (cal). This can be determined using various methods such as calorimetry, which measures the temperature change of a substance when heat is added or removed.
