Is Your Steam Saturated or Superheated?
To determine if steam is saturated or superheated, refer to the phase diagram of water, which requires knowledge of temperature and pressure. When boiling water, steam can appear clear (dry) near the spout and become visible (wet) as it cools and condenses. Dry steam is hazardous due to its latent heat of vaporization, which can cause severe burns upon contact with skin. To test steam, cool it slightly and observe for condensation; if condensation occurs, the steam is saturated. Understanding these properties is crucial for safety and effective steam usage.
zorroz
hi guys can you tell,
how to know if steam is saturated or superheated?
Science news on Phys.org
Look up the phase diagram of water. You need to know the temperature and pressure..
https://image.slidesharecdn.com/hea...p01/95/heat-transfer-16-638.jpg?cb=1355443378
When you boil a kettle the water vapour coming out can be clear (eg dry) near the spout then as it moves away it cools and condenses to visible (wet) steam. Dry steam is very dangerous because it contains the latent heat of vapourisation. When it condenses on skin it delivers a lot of energy.
Likes berkeman
Cool it a little, and see if you get any condensation.
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
