How Can You Design an Adiabatic and Reversible Thermodynamic System?
To design an adiabatic and reversible thermodynamic system transitioning from state A to B and back to A, the system must adhere to specific thermodynamic principles. The discussion highlights the challenge of maintaining an adiabatic process while avoiding heat loss during the return journey, which complicates the design. Various attempts to create PV diagrams using isobaric and isochoric steps resulted in heat being expelled, contradicting the requirements. The conversation suggests that if the adiabatic process involves expansion, it may be possible to return to state A without heat loss. Ultimately, the feasibility of such a system hinges on the specific conditions and processes employed.
decerto
Design an explicit system which does the following: It goes adiabatically and reversibly from state A to B. Then it returns from state B to state A probably irreversibly and receiving some heat from the outside world on the way. It can't give out heat.
PV^{\gamma}=c for an adiabatic process
PV=c for an isothermal process
[/B]
I attempted to draw various 3 step PV diagrams using isobaric and isochoric steps but they all gave out heat. The only way I can think of doing this is if the adiabatic process is the same as an isothermal process i.e
PV^{\gamma}=PV
\gamma=1
C_p=C_v
But this can't be true for an ideal gas so I have no idea.
Doesn't that depend on the direction of the process?
Yes but amn't I forced into a direction that gives out heat after an adiabatic process then a process which takes in heat if I want to get back to the start?
I haven't worked out the details, but if your adiabatic process is an expansion, can't you go back to state A without any heat leaving the system?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
