Solving Thévenin Equivalent Circuits: Confused by Different Methods
In solving Thévenin equivalent circuits, current sources are typically replaced with open circuits and voltage sources with short circuits. However, some instructional videos may present alternative methods, such as treating the voltage source as a load and open-circuiting it, which can lead to confusion. The variety of techniques for determining Vth can overwhelm learners, especially in a subject like circuits that many engineering students find challenging. Understanding the context of each method is crucial for accurate application. Clarity in these concepts is essential for mastering Thévenin's theorem.
gfd43tg
Hello,
For thévenin equivalent circuits, I thought current sources are replaced with open circuits and voltage sources are replaced with short circuits.
In this video, the guy replaces both with open circuits, so I am not understanding how that works.
Because of all the different methods I am seeing for solving for Vth, I cannot figure out what to do because I am being bombarded with too many techniques.
The video author is treating the voltage source as the load of the circuit so it is not strictly part of the circuit under consideration. Therefore he treats it like a load and open-circuits it.
I know this stuff is confusing. Small wonder Circuits is usually the least favorite class of Engineering majors!
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
