This is a problem on electric current
To determine how long it takes for an isolated conducting sphere with a 10 cm radius to increase its potential by 1200 V, the net inward current must be calculated from the difference between the incoming and outgoing currents. The equation V_R = q / (4 π ε_0 R^2) is used to find the charge q stored at 1200 V. After calculating the net current, the time required to transfer this charge can be derived using the relationship i = dq/dt. The discussion emphasizes the importance of understanding current flow and charge accumulation in relation to potential increase. This approach provides a clear method for solving the problem.
heavenaintclo
An isolated conducting sphere has a 10 cm radius. One wire carries a current of 1.000 002 0 A into it. Another wire carries a current of 1.000 000 0 A out of it. How long would it take for the sphere to increase in potential by 1200 V?
n/a
tried using i= dq/dt
You'll need to rearrange the following equation to find how much charge, q, the sphere will store when its surface potential is at 1,200 V.
V_R=\frac{q}{4 \pi \epsilon_0 R^2}
You know the magnitudes of the inward- and outward-flowing currents, therefore you can calculate the net inward-flowing current. All you need to do next is work out how long it takes for this current to transfer charge q.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
