This is an engineering statics question, I on trig
The discussion revolves around solving a statics problem involving two cylinders, E and F, with given weights and angles. The user has set up the equations for equilibrium but struggles with solving them, particularly in relating the forces and angles. They express frustration over their difficulty with trigonometry despite being in advanced calculus and physics courses. A suggestion is made to isolate one force in terms of another to simplify the equations, but the user questions the validity of using symmetry in their approach. The conversation highlights the challenges of applying theoretical knowledge to practical problems in engineering statics.
GreenAce92
1. If cylinder E weighs 30lb and theta = 15 degrees, determine the weight of cylinder F
2. Sigma F = 0 (Statics question)
3. I have gotten my separate components but I don't know how to solve the equations this sounds really stupid since I'm in calc III and physics II but my brain is just crapping out on me.
I have attached a sketch of the problem
The only thing(s) that are given are the three angles, and one weight.
I am having a hard time figuring out how to solve these equations.
So far I have
Sum(x) = 0 = -Fab cos30 + Fbc cos15
Sum(y) = 0 = Fbc sin30 - 30 - Fab sin15
I even have the solutions on hibbeler however I want to learn how to solve these equations, its definitely a basic concept that I should know how to do, that is solving trig problems.
Can you solve the first equation for F_{ab} in terms of F_{bc}? Once you do that, you should be able to plug that into the second equation and solve for F_{bc}.
Even with opposite signs /components?
I will try
Thank you
Question:
For the FBD on knot B
Can I not use the properties of angles that are symmetrical about a line segment to assume that Fcb cos 15 = 30cos15?
Actually in the physical sense that's not correct seeing as there is another tension force on the other side of knot b.
I think I've got it, I just hit a dumb wall of "I can't do trig even though I'm in calc III"
