Three point charges in an equilateral triangle
The problem involves three equal point charges positioned at the vertices of an equilateral triangle, with a focus on calculating the electric field at the midpoint between two charges. Initially, it was assumed that the electric field at this midpoint would be zero due to symmetry, as the fields from the two charges would cancel each other out. However, the presence of the third charge at the opposite vertex creates an additional electric field that does not cancel, leading to a non-zero resultant field at the midpoint. To solve the problem, one must calculate the distance from the vertex charge to the midpoint and determine the electric field contribution from that charge. This highlights the importance of considering all charges in the system when calculating the electric field.
Mugwump101
I had this exam question for a final exam and I was wondering if I got it right or not. There are three point charges +4q equally spaced apart at the tips of an equilateral triangle with distance .11m apart from each other. What is the magnitude of the electric field at the MIDPOINT between any two charges?
I drew a picture on paint. It's not drawn to scale but it's what was on the exam.
E=Kq/r^2
So basically, I thought the answer had to be zero. E1=-E2 kq/r^2=-kq/r^2 So the summation of the forces is zero because the charges are the same and they are the same distance apart!
However, people have been asking the TA and he says it's not zero, which makes me baffled o.O [PLAIN]http://img638.imageshack.us/img638/3060/physics0012.jpg
Well, the field from the two charges on either side of the midpoint will cancel. But what about that third charge at the opposite end of the triangle?
At mid point field due to the two charges at the end of the side is zero. But the field due to the third charge on the vertex there will be a field on the mid point. Find the distance between the vertex and the mid point and find the filled.
