Throws a stone horizontally with a velocity of 20ms-1
  • Thread starter moimoi24
  • Tags
    Velocity
In summary, Don Joriel throws a stone horizontally with a velocity of 20ms-1, 560 m above sea level. The stone hits the water after 2.04 seconds. The stone's distance from the base of the cliff is 20.39 meters.
moimoi24
48
1. Don Joriel stands on a vertical cliff edge throwing stones into the sea below. He throws a stone horizontally with a velocity of 20ms-1, 560 m above sea level.
a. How long does it take for the stone to hit the water from leaving Don Joriel’s hand?
Use g = 9.81 ms-2 and ignore air resistance?
b. Find the distance of the stone from the base of the cliff when it hits the water.
2. When Maggie applies the brakes of her car, the car slows uniformly from 15.00 m/s to 0.00 m/s in 2.50 s. How many meters before a stop sign must she apply her brakes?
please help me with those problem, I am confused. I am not sure if i got the correct answer. here are my answers 1. a. 2.04 s
b. 20.39 m
2. 18.75 m
Hope you can help me, if got the wrong answer please show me the solution... Thanks a lot...
Show your calculations.
What rl.bhat said: if you don't show us what you tried or your reasoning, then we cannot know how to help you best.
wait i'll show you when i got home.. thanks...
for 1a. i use v = u + at,
b. s = ut +1/2 at squared
for 2. s = 1/2 (u +v)t
are those correct?
are those correct?
I don't see how you can use the equation in 1a without first knowing the final velocity of the ball (I.e the velocity of the ball prior to impact with the ground). From your answer, it seems you have assumed this to be 0, but this is not the final vertical component of velocity.
For 1b, we are considering a horizontal distance. There is no acceleration of the ball in x direction so the eqn you were using simplifies to simply [itex] s = v_{ox}t [/itex].
For 2, if I understand the wording of the question correctly, you are correct.
what is the answer then? please show the solution...
are those correct?
Before you attempt this problem, please go through the projectile motion.
We are not allowed to simply hand over solutions. For 1a, you can use the equation [itex] s_y = v_{oy}t - \frac{1}{2}gt^2 [/itex] right away to find the time of descent. Alternatively, the final vertical component of velocity can be found first so you can then use [itex] v_{fy} = v_{oy} -gt [/itex].
Yet another way is to do all three problems via sketching v-t diagrams for each of the x and y components of velocity.
what is the answer on the problem? i am totally confused.. please help me...
i didnt get your equation because of so much symbols, sorry...
i got it already... thanks...
how about number 2?
Can you find the time taken by a stone dropped from a height 560 m?
Ok, for 1a, initial vertical component of velocity is 0, right? This is because the ball is projected horizontally. So in our equation, [itex] v_{oy} =0. [/itex] The eqn therefore reduces to [itex] s_y = \frac{1}{2}at^2. [/itex] If you define downwards as negative, then the ball will fall downwards 500m so [itex] s_y = -500m. [/itex] Think of the ball moving 500 units down the y-axis (I.e starts at y =0 and finishes at y = -500). Now, if downwards is negative, a =-g and so our final equation is [itex] -s_y = -\frac{1}{2}gt^2 [/itex] Rearrange for t and you are done with 1a.
so t = 10.68... by the way where did you get 500? is it 560?
how about 1b?
Yes, sorry 560m not 500m. For 1b, again use the relation [itex] s_x = v_{ox}t + \frac{1}{2}at^2, [/itex] but this time considering the x direction. No forces act on the body in the horizontal direction so ax = 0. The horizontal distance covered will be proportional to the time of flight because of a constant (non zero) horizontal component of velocity.
Please tell us what you got... be specific: it makes sure we have not accidentally sent you up the wrong tree. When you show working, also be specific: we need to see your reasoning, like how you used an equation, in order to help you properly.
CAF is doing the detail work. Can you see how CAF is choosing which equation to use?
is this correct for 1a.
-560 = -1/2 (9.81) t^2
t = 10.68
im not sure if that s correct
t = 10.68
Yes, that is correct. But do you understand why? What makes you unsure?
How did you get on with 1b?
tell me if i got 1b correct.
i use your formula,
s = 20 m/s (10.68 s)
s = 213.6 m...
is it right?
thanks a lot...
how about the number 2? this is my solution:
s = 1/2(u+v)t
= 18.75 m
Yes, all questions are correct now. I would now suggest a few more problems to make sure you are on top of things.
so i got all correct? even the second?
thanks a lot...
No problem, keep doing exercises and with time you will really understand things.
Thank you so much for the help...
1. What is the initial velocity of the stone?
The initial velocity of the stone is 20 meters per second (20ms-1). This means that the stone is moving horizontally at a speed of 20 meters per second.
2. What does it mean to throw a stone horizontally?
Throwing a stone horizontally means that the stone is being launched in a straight line parallel to the ground, with no upward or downward movement.
3. How far will the stone travel?
The distance the stone will travel depends on a variety of factors, including air resistance and the height at which the stone is thrown. However, assuming no external forces, the stone will travel a horizontal distance of 20 meters in one second.
4. How long will it take for the stone to reach the ground?
The time it takes for the stone to reach the ground will also depend on external factors such as air resistance and the height at which the stone is thrown. However, assuming no external forces, the stone will take one second to reach the ground.
5. What is the acceleration of the stone?
Since the stone is moving horizontally at a constant velocity of 20ms-1, the acceleration is zero. This means that the stone is not speeding up or slowing down in the horizontal direction.
