How Does Wavelength Affect Scattering Angle in Light?
The discussion revolves around the relationship between light wavelength and scattering angle, specifically in the context of sunlight colors A and B. It is noted that if color B is scattered at an angle 16 times greater than color A, the wavelength of color B is half that of color A, based on Rayleigh scattering principles. Participants express confusion over the correct approach to solving the problem, with suggestions to clarify the relationship between wavelength and scattering. The conversation highlights the importance of understanding diffraction and scattering concepts in physics. Ultimately, the key takeaway is that the scattering intensity, not the angle, is the critical factor in determining the wavelength relationship.
Dx
If sunlight of color B is scattered through an angle 16 times greater than sunlight of color A, then the wavelength of color B is?
Dx :wink:
Dx, you should know by now that you have to show your work.
Tom,
I have been doing just that but if I don't know what to do then why should i put down anything 'ol down. By putting just something down not only wastes your time and mine but I think insults our intellengence as well. I am not here to try and bs anyone. I understand your rules and do comply, sir. But I can't put anything down which I do not have. Thats why I am asking for help.
Thank you, Tom!
Very respectfully,
Dx :wink:
You could at least say you don't know where to start so you can get some hints. :P
I believe this is understood stuffy. If I don't say anything since the forum states "you must include your work with the problems" but I don't want to beat a dying horse here so forget it. I am asking for help you can choose to help or not that's your decision. I don't want to argue with anyone, just asking for anyes help who wants to if not its ok. Anyways, can someone justdelete this thread since its really getting off the subject of what I have asked, please.
Later.
Dx
OK, I assume this is scattering by diffraction. First tell me what is the relationship between wavelength and diffraction angle.
See this is what thorws me off too. I am unclear what to do so let's go with what your saying if its not right ok then but at least i learned something.
I know defraction refers to the fact that light, likr other waves bends around objects it passes and spreads out thru narrow slits. This patter has interference between rays of light that travel distances which gives me this formula
sin[the] = [lamb]/D. I am to assue that the ans is simply 1/16 of that color of A or no?
Dx
This is the formula for 2-slit interference; I was thinking that it was single-slit diffraction. But OK, let's proceed with this one. If the other one was intended, it is a simple thing to fix.
No, you are supposed to calculate the answer to find out what it is. Set up two equations as follows:
sin(θA)=λA/D
sin(θB)=λB/D
You also have:
16θA=θB
You need to solve for the ratio: λB/λA.
This is not easy to solve, and I am thinking we are on the wrong track by interpreting "scattering" this way. In your book, what topics are discussed in the section in which this problem appears?
Im just going to be lazy and link to this because its pretty much the same principle, you need to determine the y value before finding the angle thinks I.
Dx :wink:
I suspect what Dx is talking about is Raleigh Scattering, which is dependent on wavelength and goes as the inverse fourth power of the wavelength, which means B is half the wavelength of A. The factor of 16 is the scattering intensity and not the angle.
