Calculators TI-89 Differentiation: How to Get Algebraic Derivative and Why Negative Result?
To obtain the algebraic derivative of a function using the TI-89 calculator, ensure that the variable x is not defined as a constant. If x has been assigned a numerical value, it must be cleared to return to being a variable. To do this, access the VAR-LINK menu and delete any stored items associated with x. Regarding the discrepancy in outputs for sin(60) between the TI-89 and TI-83 calculators, it is essential to check the calculator's mode settings. The TI-89 may be set to radians, resulting in a negative output, while the TI-83 is likely set to degrees, producing a positive result. Always confirm that the calculator is configured to the correct angle measurement mode before performing trigonometric calculations.
Helicobacter
1. After I launch the "Home" program and enter
d(x^2,x)
The calculator spits out -52.4916, a numerical solution. What I want is the algebraic derivative 2x - how do I get to the algebraic derivative?
2. When I enter sin(60), it gives me -0.304811 as an output. Why does the Ti-89 give a negative result, while the Ti-83 provides me with a positive one?
Sorry if I'm in the wrong forum. The forum search didn't spit out anything.
Computer science news on Phys.org
1. Make sure you don't have x defined as some constant. If you just enter 'x,' what does it return?
2. Make sure the calculator is set for degrees, not radians.
- Warren
- Warren
Thank you for your feedback, Warren. You are right, I associated a number with x. How can I make it a variable again?
I think there's a menu option, I think second then f1, or maybe f5 will give you the option to clear a-z or maybe it's under the var-link think which would be second then "-". The batteries in my 89 are dead so I can't check which one it is, but I'm pretty sure it's one of those.
I have my TI-89 right here, so I'll look. Yep, go to VAR-LINK and scroll down until you see stored items and you should see "x" there. Delete it and you're good!
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
I came across a video regarding the use of AI/ML to work through complex datasets to determine complicated protein structures. It is a promising and beneficial use of AI/ML. AlphaFold - The Most Useful Thing AI Has Ever Done https://www.ebi.ac.uk/training/online/courses/alphafold/an-introductory-guide-to-its-strengths-and-limitations/what-is-alphafold/ https://en.wikipedia.org/wiki/AlphaFold https://deepmind.google/about/ Edit/update: The AlphaFold article in Nature John Jumper...
9K
15K
11K
