Calculating Speed for Time Dilation in the Twin Paradox
In summary: You have two equations: ##\Delta T = \gamma \Delta T_0## and ## \Delta T = 2D/v##.You may be able to solve for ##v## by solving for ##\Delta T_0## and then substituting that into the first equation. However, this will involve solving two equations at once and I'm not familiar enough with simultaneous equations to do that.You may be able to solve for ##v## by solving for ##\Delta T_0## and then substituting that into the first equation. However, this will involve solving two equations at once and I'm not familiar enough with simultaneous equations to do that.
k3r0
"A star is 5ly away. If an astronaut wants to travel there and back and only age half a year, at what speed β = v/c do they need to travel?"
[tex]\gamma = \frac{1}{\sqrt{1 - v^2/c^2}}[/tex]
[tex]\Delta T = \gamma \Delta T_0[/tex]
so [tex]\Delta T = \frac{\Delta T_0}{\sqrt{1 - v^2/c^2}}[/tex]
I'm having problems finding the time elapsed on Earth (T0) without knowing the speed, v/c. I've tried to use [tex]\Delta T_0 = \frac{2l}{c}[/tex] and then put my answer into the equation for delta T, but my answer ended up being 20c which is definitely not right... I've tried it in both ly and in meters. I also tried equating 2d/c and 1/gamma * T but had too many unknowns to solve. Any help with this would be appreciated; this is the first question in a set of problems and whilst I've done the other 'harder' ones, I can't do this one. I feel like I'm missing something really obvious? I've tried to search for other equations for time elapsed on Earth but to no avail. Thank you.
Welcome to PF!
Are you sure that ##T_0## is Earth time? What is your justification for that?
TSny said:
Welcome to PF!
My lecturer gave me the equation:
[tex]\Delta T' = \gamma\Delta T[/tex]
Wouldn't T' be for the astronaut and normal T is elapsed on Earth?
Upon reflection I tried it the other way around and did this:
[tex]\Delta T = \frac{2D}{c} = \frac{10c-yr}{c} = 10[/tex]
[tex]\Delta T = \frac{\Delta T'}{\sqrt{1 - β^2}}[/tex]
[tex]10=\frac{0.5}{\sqrt{1 - β^2}}[/tex]
[tex]0.5 = 10\sqrt{1 - β^2}[/tex]
[tex]β^2 = 0.9975[/tex]
[tex]∴ β = 0.99875 (i.e. v = 0.99875c)[/tex]
I think this seems to be a reasonable answer? Since you can never actually travel at the speed of light. I'm not convinced I've done it correctly though.
It's important to understand the meaning of "proper time interval" and be able to identify which observer measures the proper time interval. The round trip "twin-paradox"" is a little tricky because the astronaut switches inertial reference frames when turning around. But think about just the trip out to the star where the astronaut stays in one inertial frame. Does the astronaut or the Earth observer measure the proper time interval for the outgoing trip?
[tex]\Delta T = \frac{2D}{c}[/tex]
Looks like you assumed the astronaut is traveling at the speed of light here. How would you correct that?
The astronaut? Because they're on the same plane moving with the rocket for the duration as the trip so the proper time is the time measured by them. I think so, anyway.
I don't know. This is the reason I've been stuck on this problem for the past 5 hours; if I put β into this equation then I can't find Delta T so I have two unknowns and can't complete the problem. I'm considering using simultaneous equations at the minute but so far I haven't been successful.
Yes, that's right. The observer who measures the proper time between two events is the observer for whom the two events occur at the same place in their frame of reference. For the astronaut, the event of leaving the Earth and the event of arriving at the star occur at the same place.
Try combining these two equations to get an equation that involves just ##v, D## and ##\Delta T_0##. Then you'll have some algebra to do to solve for ##v##.
1. What is time dilation and how does it relate to the twin paradox?
Time dilation is a phenomenon in which time runs slower for an object or person in motion compared to a stationary object or person. This is a key concept in the twin paradox, which is a thought experiment that explores the implications of time dilation on the aging of twins who have different motion experiences.
2. Can time dilation be observed in everyday life?
Yes, time dilation has been observed in many experiments and is a well-established principle in the theory of relativity. For example, GPS satellites have to account for time dilation in order to provide accurate location information on Earth.
3. How is time dilation calculated?
Time dilation is calculated using the formula t' = t√(1-v^2/c^2), where t' is the time in a moving reference frame, t is the time in a stationary reference frame, v is the velocity of the moving object, and c is the speed of light. This formula shows that as an object's velocity increases, time dilation becomes more significant.
4. Does time dilation only occur in objects traveling at high speeds?
No, time dilation can occur in any situation where there is relative motion between two objects. However, the effects of time dilation become more noticeable at higher speeds, which is why it is often associated with objects traveling close to the speed of light.
5. How does the twin paradox challenge our understanding of time?
The twin paradox challenges our intuitive understanding of time as a constant and universal concept. It shows that time can be experienced differently by different observers depending on their relative motion. This concept has been confirmed by numerous experiments and is a fundamental principle in the theory of relativity.
