How long to reach Mars at 11,000 m/s?
  • Thread starter Thread starter terpsgirl
    Mars Time
To calculate the time to reach Mars at a speed of 11,000 m/s, the correct formula is t = d/v, where distance must be in consistent units. The distance to Mars, 78.3 x 10^6 km, should be converted to meters, resulting in 78.3 x 10^9 meters. The time calculated is approximately 7,118,181.81 seconds, which equates to about 82 days, not 71 seconds as initially suggested. Proper unit conversion and tracking are crucial to avoid errors in physics calculations. Understanding these principles will help clarify similar problems in the future.
terpsgirl
A rocket moves through space at 11,000 m/s. At this rate, how much time will be required to go to Mars (78.3 x 10^6 km)?
i used t= d/v
and got 5.05 x 10^ -4
I'm not sure what I'm doing wrong. I can't get the correct answer
Neither am I, because you haven't shown any of your steps.
How did you get your answer?
Why don't you show us the exact numbers you are plugging in. Don't forget to use consistent units. For example, don't mix meters and kilometers.
11,000 m/s
__________
21,751,740 = 5.05 x 10^ -4
I got my numerator figure by converting 78.3 x 10 ^6 km
and got 21,751,740 m/s
You can't convert km to m/s. The former is a distance, the latter is a speed.
You should have converted 78.3 x 106 km to meters. The numerical value will only differ by a power of 10. Also, you're dividing in the wrong order. The speed v goes on the bottom, and the distance d goes on top.
I got 71181818.18 = 71 seconds as my answer. THX :)
The answer is t=7118181.81 seconds (which is about 82 days). You can't round that to 71 seconds (which is a minute and 11 seconds).
Uh, I think Tom meant the they would differ by A power of 10, not that 78.3 x 10^6 km equaled 78.3 x10^10 meters. To go from km to meters, multiply by 1000 (or just change the power of ten by three - 78.3 x 10^6 to 78.3 x 10^9)
And how did 71 plus million seconds suddenly turn into only 71 seconds. You might want to convert your 7 million+ seconds into something a little more manageable such as days, for example.
Tracking dimensions
There's a really good technique that a physics teacher taught me (although it's probably common use.) For now, whenever you do a physics problem, you should keep track of the units.
Here's an example problem which is similar to yours:
So, let's say we have a car that is traveling at 5 \times 10^2 feet/sec and we want to know how many days it will take to drive 7 \times 10^5 miles.
So, of course, we start withd=vt. Since we want to solve for time, we divide both sides by v so we have t=\frac{d}{v}
So, let's plug in the numbers:
t=\frac{d}{v}=\frac{7 \times 10^5 miles}{5 \times 10^2 feet/sec}=1.4 \times 10^3 \frac{sec \times miles}{ft}
Of course, second miles per foot are not appropriate units, since we want days. So we can do the following:
1 mile=5280 ft
1=\frac{5280 ft }{1 mile}
so
t=1.4 \times 10^3 \frac{sec \times miles}{ft} =1.4 \times 10^3 \frac{sec \times miles}{ft} \times 1 =
1.4 \times 10^3 \frac{sec \times miles}{ft} \times \frac{5280 ft}{1 mile}=7 \times 10^6 sec
Note that the miles and feet cancel nicely when you multiply out.
Now, to get from seconds to days, you can use a similar approach:
7 \times 10^6 sec \times \frac{1 minute}{60 seconds} \times \frac{1 hour}{60 minutes} \times \frac{1 day}{24 hours}\approx 1.2 \times 10^1 days
If you write up your problem in a similar fashion, you're less likely to make mistakes, and people here, and your teacher, will have an easier time helping you.
P.S. I was playing a bit fast and loose with sig figs there. You should be more careful.
Every physics teacher should teach about keeping track of units! That's a basic concept :).
By the way, I am still wodering if "NateTG" is "Nate the great" who was "12 years old" for more years than I can remember! If so he has finally grown up. His responses actually make sense now!
Since you're in VA, probably not.
