To produce electric field to polarise water
Creating a high potential electric field for an electrostatic coalescer project is feasible even with insulated electrodes, which still produce an electric field. However, generating 20 kV safely and economically poses significant challenges, particularly for someone without prior high voltage experience. The discussion highlights concerns about safety and the necessity of mentorship from a skilled faculty adviser. Attempts to seek guidance from the physics department have not yielded results, emphasizing the need for expert support. Ultimately, the project is deemed too dangerous for further discussion, with a recommendation to consider a lower voltage topic.
mmmohit5
i am pursuing b tech in marine engineering. for the final year project i have selected electrostatic coalescer. i need to create a very high potential electric field in which i am having certain trouble. i have doubts regarding the following points:
1. does electric field will still be created if the electrode is insulated.
2. how to generate high potential in an economical way? is there any appliance available which is cheap and also meets our criteria. i need to achieve 20 kv .
Welcome to the PF.
Yes, insulated electrodes still produce an electric field. And in the case of this device, using insulated electrodes sounds important.
I'm troubled that you haven't worked with high voltages before, and are now trying to tackle a project at 20kV. Do you have a skilled faculty adviser who can Mentor you in electrical safety?
Can you provide some web pointers to similar devices so we can see how they are constructed and used?
no sir we do not. I have been trying to get help from the physics dept. but they do not have any expert on this field.
I would be of much help if you could help me.
No, sorry. This project is too dangerous to be discussed here. I recommend that you try to change your project to a low-voltage topic. This thread is closed.
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
