How Do I Calculate Energy Changes in Thermodynamics Problems?
  • Thread starter Thread starter Roro312
    Test
To calculate energy changes in thermodynamics problems, start by determining the energy required for phase changes and temperature increases. For the ice cube, first convert it from solid to liquid using the formula E = mLf, then raise the temperature to the boiling point, and finally convert the liquid to vapor using E = mLv. In the case of the mandarin orange, calculate the energy needed to raise the temperature of the water using Q = mc(Tf - Ti), where m is the mass of the water and c is the specific heat capacity. Combine all calculated energies to find the total energy for each problem. Understanding these formulas is crucial for solving thermodynamics questions effectively.
Roro312
Tomorrow is my test and i understand partially everything... and than i stumbled upon these two questions and if i just know what's used for each formula .. i can do it
1) Calculate the amount of energy required to evaporate an ice cube having a mass of 45g.
I know that first it must go for solid to liquid which is E=mf and than from liquid to gas which is E=mLv .. can someone please show me how to do them... my test is tomorrow:(
Lf water= 3.3x10^5 J/Kg
water=4.2x10^3 J/Kg'C
ice= 2.1x 10^3 J/Kg'C
the other question i didnt get was:
2)An 80g mandarin orange is burned in bomb calorimeter. The 1.55 kg of water change in temperature from 21.0'C to 39.4'C. Calculate the energy per gram in the mandarin orange.
I would show you my attempt except its just ridiculous becuase i reallyyyy don't get it.
Your help is muchhhh appreciated.. i need help ASAP ...thank you
Well for the first one, you will need energy to
1)convert the ice to liquid which is (solid to liquid)
2) Raise the temperature to the boiling point of water
3) convert all the liquid to vapor
So find the individual energy requirements and add them up.
For the second one, how much energy would it take to raise the temperature of water of mass 1.55kg from 21C ro 39.4C?.
Thats the problem... i don't know how to convert solid to liquid.. what formula do i use?
Q=mC C is a constant you can look up for water its different depending on which phase transition you are calculating.
Q=mc(Tf-Ti) for when your raising the temperature c i think its 1cal/gC for water.
Add all the Qs and viola
