Effect of load voltage variation in this circuit
Load voltage variations in the discussed circuit primarily affect the collector current of Q2, which is regulated by the resistance of R2 and the voltage across it. The circuit employs a negative feedback mechanism that mitigates the early effect, ensuring that load current remains relatively stable despite changes in load voltage. As load current increases, the voltage drop across R2 and VbeQ1 rises, enhancing Q1's operation and consequently reducing Q2's collector current to maintain load current levels. Conversely, if load current decreases, the feedback mechanism adjusts Vbe1 and Vbe2 to restore the previous load current value. Overall, the circuit effectively stabilizes load current through its design.
brainbaby
If load voltage vary..will Vce_Q1 changes in opposite direction in order to compensate change in Vce_Q2 in order to eliminate early effect in Q2...??
Hey, that circuit is from Horowitz and Hill :smile:
The collector current of Q2 is mostly set by the current through R2, which is set by its resistance and the voltage across it (which is being held at about a diode drop by the E-B junction of Q1. As long as the load voltage doesn't get big enough to take Q2 out of the active region, the load current should be pretty independent of the load voltage.
Likes brainbaby
Forget about early effect in this circuit. this circuit has a negative feedback mechanism which reduce the early effect.
As load current tries to increase his value, the voltage drop across R2 and VbeQ1 also increases. This turns-ON Q1 harder (Ic1 current increase ), larger Ic1 current increase voltage drop across R1 resistor this reduces the Vb2 voltage and Vbe2 in the same time, thereby reducing the collector current of Q2 and load current.
As you can see negative feedback restore the previous value of a load current.
The same things happens when load current tries to decreases. In this case Vbe1 is dropping which reduces Ic1 collector current, this make less voltage drop across R1.
So Vbe2 must increase his value and in result bring back the previous value of a load current.
Likes brainbaby and berkeman
thanks buddy i got it...great job
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
