Topology - Use Componentwise Convergence Criterion to prove closed ball closed.
t00dles23
Let r be a positive number and define F = {u in R^n | ||u|| <= r}. Use the Componentwise Convergence Criterion to prove F is closed.
The Componentwise Convergence Criterion states: If {uk} in F converges to c, then pi(uk) converges to pi(c). That is, the ith component of the sequence converges to the ith component of c.
What we want to show is that if {uk} in F converges to c, then ||c|| <= r.
It's easy to show it without the componentwise convergence criterion, as follows:
||c|| <= ||c - uk|| + ||uk||. Taking the limit as k goes to infinity, we get ||c|| <= 0 + ||uk|| <= r. But I need a proof that does use the CCC.
I tried this:
Suppose {uk} in F converges to c. Then pi(uk) converges to pi(c) by the componentwise convergence criterion. So:
|pi(uk)| <= ||uk|| <= r
|pi(c)| <= r
(pi(c))^2 <= r^2
\sum_{i=1}^{n} (p_{i}(c))^2 \leq \sum_{i=1}^{n} r^2
\sqrt{\sum_{i=1}^{n} (p_{i}(c))^2} \leq \sqrt{nr^2}
||c|| <= (n)^(1/2)*r
but this isn't a strong enough statement, because I need ||c|| <= r. Advice please?
If pi(uk) --> pi(c) for every i, then what happens to the sequence
\sqrt{\sum_{i=1}^n{p_i(u_k)^2}}
as k goes to infinity? To which number does this sequence converge?
I don't think I understand your hint. I mean sure, ||u_k|| --> ||c||. But I don't know what that does for me. It seems to just point back to the proof using ||c|| and the triangle inequality, but that doesn't use the componentwise convergence criterion. Can you elaborate?
Nevermind. I understand now. Thank you for your hint.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
