Solving for Torque and Angular Speed in an Engine
To determine the constant torque required to bring an engine wheel with a moment of inertia of 2.80 kgm² to an angular speed of 360 rev/min in 7.60 seconds, an angular acceleration of 4.96 rad/s² was calculated. The torque was found using the equation torque = I * alpha, resulting in 13.89 Nm. For calculating final kinetic energy, the standard kinetic energy formula was initially questioned due to the absence of mass, but it was clarified that the rotational kinetic energy formula can be used instead. The discussion emphasized understanding the relationship between torque and angular acceleration as analogous to Newton's second law. The conversation concluded with a positive acknowledgment of the guidance received.
Heat
[SOLVED] Torque & Angular Speed
The wheel of an engine has a moment of inertia 2.80kgm^2 about its rotation axis.
What constant torque is required to bring it up to an angular speed of 360 rev/min in a time of 7.60 s, starting from rest?
What is its final kinetic energy?
torque = rF sin(theta)
k=.5mv^2
First I converted 360 rev/min to seconds
so
360 (rev/min) ( 1 min/60s)( 2pi/rev) = 37.699 rad/s
t = 7.60
I = 2.80 kgm^2
so I decided to get angular acceleration, in case I need it is
alpha = 4.96
From what I spotted in my book Sum of torque = I(angular acceleration)
torque = (2.80)(4.96)
torque = 13.89
this is right, but is they way I have done it correct or did I just get lucky. I am afraid I just plugged into the "sum of torquez = I (angular accelerationz)"
without understanding it :O
part two of the question is
for this
K=.5mv^2
how do I implement this into the problem if I don't have mass?
omega = omega initial + alpha(time)
so
t = 7.60
I = 2.80 kgm^2
alpha = 4.96
torque = 13.89
That's fine. Realize that the equation "Torque = I*alpha" is just the rotational version of Newton's 2nd law; the translational version (which you know and love) is "Force = mass*acceleration".
for this
K=.5mv^2
You don't need mass. For rotational kinetic energy, use I. What's the rotational version of the kinetic energy formula?
Read this: Rotational-Linear Parallels
Great! Thank you very much Doc Al, you are the greatest. :)
