Torque and Equilibrium of a rope climber
geah
A climber with a weight of 533.8 N is held by a belay rope connected to her climbing harness and belay device; the force of the rope on her has a line of action through her center of mass. The indicated angles are 40 degrees and 30 degrees. If her feet are on the verge of sliding on the vertical wall, what is the coefficient of static friction between her climbing shoes and the wall. (40 degrees is the angle between her feet and the wall, 30 degrees is the angle between the rope and the wall)
torque = rxF
First off I drew a free body diagram of the situation. Because torque must equal to zero we know that the torque counterclockwise = torque clockwise. Knowing this I put the information into the equation and got r Ff sin(110) = r/2 (533.8) (cos 70) what's stumping me is the fact that I have 2 variable and I can figure out how to move from here.
If you could offer a clean explanation that would be wonderful,
Thanks
~geah
It's unclear to me what point you are using as a reference in calculating torques. (In any case, the "r" drops out of this equation, leaving you with one variable.)
I suggest you solve this in multiple steps. First take torques about the point where her foot contacts the wall. This will allow you to find the tension in the rope.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
