Why is it Easier to do Sit-Ups with Hands on Stomach?
  • Thread starter 9giddjl
  • Tags
    Torque
In summary, the placement of your arms during sit-ups affects the distance from the axis of rotation, which in turn affects the polar moment of inertia. This can make it easier or harder to perform the sit-ups depending on the placement of your arms.
9giddjl
35
Hello!
I have a question: Why is it easier to do sit-ups with your hands on your stomach, than with your hands behind your head?
Our teacher told us that it is easier because the moment arm is closer to the axis of rotation.. but I still don't fully understand..because I also read in my physics textbook that, for example, if you were to use a wrench, putting your hands farther away from the axis of rotation makes it easier to rotate the wrench.. and also, what is happening to the force for all of this?
any help would be greatly appreciated :)
thanks in advance ~~
When you turn a nut with a wrench, you use an exact amount of energy for it. That Energy can be given by a long distance motion and small force(hand on wrench end) or short distance motion and big force(hand near axis or rotation). The product of the Force and distance is equal in both cases.
What your teacher is talking about is polar moment of inertia http://en.wikipedia.org/wiki/Polar_moment_of_inertia.
It requires less torque to rotate something with a lower polar MOI. The MOI increases linearly with mass but with the square of the distance from the centre point.
This is why it's easy to hold out a tin of beans close to you, but really hard to hold it at arms length. It's the same with the sit up, your CoG will move depending on where you put your arms.
On saying that i'd tend to disagree with your teacher in this specific case, putting your arms at different locations will not tend to alter your centre of gravity much. It's probably that putting your arms behind your head stretchs your back muscles causing them to work against the abs pulling you in.
1. Why is it easier to do sit-ups with hands on stomach?
There are a few reasons why it may be easier to do sit-ups with your hands on your stomach. First, placing your hands on your stomach can provide a counterbalance, making it easier to lift your upper body. Additionally, placing your hands on your stomach can help engage your core muscles, making the sit-up movement more efficient. Lastly, having your hands on your stomach can help you maintain proper form and prevent strain on your neck and back.
2. Is it necessary to have your hands on your stomach while doing sit-ups?
No, it is not necessary to have your hands on your stomach while doing sit-ups. Some people may prefer to have their hands crossed over their chest or behind their head. It is important to find a hand position that is comfortable for you and allows you to maintain proper form throughout the exercise.
3. Can having your hands on your stomach make sit-ups more challenging?
Yes, having your hands on your stomach can make sit-ups more challenging. This is because it requires more effort to lift your upper body without the assistance of your arms. Additionally, having your hands on your stomach can help engage your core muscles, making the exercise more intense.
4. Are there any alternatives to placing hands on stomach during sit-ups?
Yes, there are several alternatives to placing your hands on your stomach during sit-ups. As mentioned before, you can cross your arms over your chest or place them behind your head. You can also hold a weight or medicine ball to add resistance to the exercise. It is important to find a hand position that allows you to maintain proper form and engage your core muscles.
5. Can placing your hands on your stomach cause any harm during sit-ups?
No, placing your hands on your stomach should not cause any harm during sit-ups. However, it is important to listen to your body and make adjustments if you experience any discomfort. If you have any pre-existing injuries or conditions, it is best to consult with a doctor or physical therapist before attempting sit-ups or any other exercise.
  • Classical Physics
