Torque & Power for Frame Tilting Arrangement
  • Thread starter Thread starter vishugupta
    Power Torque
The discussion revolves around calculating the torque and power needed for a frame tilting arrangement that rotates a 15-tonne shaft with sheet metal stacks. The user initially calculated torque using mass moment of inertia and angular acceleration but received unexpectedly low values due to the slow rotation speed of 0.02 RPM. Clarifications were sought on whether the shaft's balance affects torque calculations and the appropriate time to use for angular acceleration. It was confirmed that if the shaft is balanced, friction is a significant factor, and a motor with a couple of hundred watts could suffice for the task. Additionally, the user inquired about summing the mass moments of inertia of different bodies rotating about the same axis to determine the total moment of inertia for the system.
vishugupta
hi,
i am doing a project on frame tilting arrangement where the sheet metal stacks mounted on a shaft have to be rotated by 180 degrees. the mass of the shaft is 15 tonnes. to calculate the torque required i found the mass moment of inertia and multiplied it by angular acceleration. the total time taken to rotate the stacks is 25 minutes.so the speed is extremely slow. since the setup reaches the speed instantaneously, for calculating angular acceleration i took time as 0.1 sec(i don know whether this is right). i got very low torque value and also low power.(it came in watts!). i don't know the mistake . please help asap.
Is the shaft really perfectly balanced if there are frames mounted on it? Perhaps you could clarify/draw a diagram of the situation...
If, indeed, the shaft is perfectly balanced, then friction forces are the largest factor in figuring out how fast you can rotate it.
But I would certainly think that a couple hundred watt motor could provide enough torque to turn it if you are looking to rotate it over a period of many minutes. When you gear down the motor that far, the torque can be enormous.
hi,
the shafts are perfectly balanced. they have a pair of c-brackets. i have attached a schematic drawing. the torque is very high. and the speed of 0.02 rpm is reached instantaneously .
so to find the angular accln, what is the time to be taken for calculation purpose. please guide me.
this is the pdf format of my drawing.
one more question...
can we add up the mass moment of inertia's of different bodies rotating about the same axis to get the total mass moment of inertia of the entire system...?
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
