Torque when there is variable force
To calculate torque when force varies with distance, integrating the force over the length of the object is necessary. The correct approach involves using the force per unit length, denoted as f (in N/m), to find the force acting on a small section of length dr, which is f·dr. The torque on that section can then be determined, leading to the total torque calculation. This method clarifies the relationship between force and distance in the context of variable forces. Understanding these principles is crucial for accurately solving torque problems in physics.
fondbeech
There is a force that varies with the distance from the origin. Can I solve for the torque by integrating the force over the length of the object that the force acts on? Is it integral of F dr or F*r dr?
torque=FxR
I thought that torque could be the integral of F dr but I'm not sure if that is right.
Welcome to Physics Forums.
torque=FxR
Instead of being given the force, you should really be given the force per unit length (units of N/m).
Calling f the force per unit length, the force on a small section of length dr would then be f·dr. So, what would be the torque on that section? From there, it should be evident how to get the total torque.
