Designing a Torsion Test Equipment for Mechanical Engineering Project
The discussion centers on designing torsion test equipment for a mechanical engineering project, focusing on torque calculations. The student seeks to determine the maximum torque the drill chuck can hold before slipping, emphasizing the need for a secure grip on the specimen. Suggestions include ensuring the chuck is in good condition and possibly modifying the specimen to improve grip. The importance of recording torque readings upon specimen failure is also highlighted. Overall, the conversation underscores the significance of proper equipment setup and testing to achieve accurate results.
xy7z
Hello,
I'm a student of mechanical engineer and currently doing a project on "fabricating a torsion test equipment".
I'm just wondering about my torque calculations.
My design is quite simple, consists of:
- angle iron (frame)
- torque angle gauge (to measure angle of twist)
- 2x 1/2" drill chucks (one fixed at the other end and one is rotating with a torque wrench as an applying force)
Now, the question is, how do i calculate the "maximum torque" or force (at the fixed one) it can holds? My specimen is 10mm diameter with 100mm of length.
Regards,
Ren
If the torque wrench that you use to apply the load has a maximum reading indicator, that will give you the data you seek right there.
What i understood from your reply, when the specimen breaks, i will just record the reading from the torque wrench (Nm)?
If that's what you meant, my question is still unanswered, i am finding the maximum force (torque) the drill chuck can grip the specimen until it slips.
If the drill chuck slips, then your fixture is inadequate. The whole point of the chuck is to not slip but rather to transfer twist to the test item.
file three flats on end of your specimen to mate with the chuck's teeth?
for all we know your specimen is made of material too hard to grip or your chuck might be worn out.
one experiment is worth a thousand expert opinions.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
